05-15-2017, 07:53 PM | #1 |
truck has own schedule
Well everything I had planned for upgrades later ,the truck has stepped up.
Heads with larger valves and mild porting.It stuck intake on #4 and broke push rod. So now have heads at machine shop. Little more cam. well heads are off and only thing to change now would be harmonic and TC being pulled.Orderede it today. Already torn down so half of work done. Aluminum intake.Dang thing weighs 51 lbs and pain to handle. New edlebrock on the way. Exhaust comes after trans swap,which is now on budget hold. Got to love these old things.LOL
Only the stupid know too much to learn something new. |
05-15-2017, 08:22 PM | #2 |
Registered Truck Offender
Re: truck has own schedule
well of course!!!! This is why most of our hobby trucks are named some FEMALE name (or called a mother of a dog preceeding that name) Few are named Henry or Sam, nooo!! most are named fatB**ch Burtha or Christene or sheDevil... Like the 'real thing'' MAN will be bending to THEIR schedule until time runs out.
LOL and we know why.... .. Dont we LOL
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
05-16-2017, 08:58 AM | #3 |
I feel your pain. I was on my way to get my bed painted when the transmission went out. After pulling the trans, I figured I might as well replace the leaking rear main seal and oil pan gasket. After pulling those, I realized my nylon timing gear was broken into a hundred pieces and clogging up the oil pump. After pulling the timing cover I realized my balancer was scored badly. I think I finally found the bottom of the hole and am in the process of getting everything back together... It's all stuff that needed to get done but man is it a bummer when you get derailed like that.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
05-16-2017, 02:57 PM | #4 |
motor exploder
I went through this last year... Went for a test drive after installing my fancy new AGR power steering box & pump, hammered down on it, heard a loud expensive 'bang' followed a by the sound of metal rattling around at about 6500 rpm. #1 intake valve head broke off, fell into the chamber and took out the bottom end of a very fresh 454. Threw my plans & budget WAY off. I just now got another motor to put back in the thing.
We feel your pain, and as usual, Marv D is right on the money .
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-17-2017, 09:30 AM | #5 |
Thats some tuff breaks boys! Got my fingers crossed but i have a gut feeling its just a matter of time before we all have an experience similar to you guys...
05-17-2017, 10:43 AM | #6 |
And when you start showing some attention to one girl (truck), your other girl (wife, girlfriend, etc) will want attention just as much...
05-17-2017, 01:01 PM | #7 |
05-18-2017, 04:09 PM | #8 | |
Heads back tomorrow.6 or 8 hours grinding and reassemble tomorrow night. Install heads and cam Saturday. Was not schedule or order In wanted ,but hell I'm there might as well get something out of all of the work. Heads will be temporary. Better ones to come with intake and headers,after trans swap.So is the plan and it has worked so well up till now.LMAO
Only the stupid know too much to learn something new. Last edited by chris mc bride; 05-18-2017 at 04:14 PM. |
06-01-2017, 10:23 PM | #9 |
Ok heads fixed,well after 12 hrs grinding ,new guide and new valve.Well maybe the grinding wasn't a have to do,for most folks.
New Comop cam XE268 cam installed,should have gone little bigger.Need little more choppy idle. Get it all back together and seems throw out bear ing is about ready to be thrown out.Looks like trucks more ready for the 4l80e to go in,cash flow not so ready.$550 for controller and 250 for speedo adapter of not ready. Well add in 300 for 3.73 swap planned to go with trans swap. I thought getting this thing going was going to be cheaper than building FED I plan on pulling to local show with it.LMAO
