Old 12-08-2019, 12:30 PM   #1
Ultrasummer
Oil Changing Woes
So I'm changing the oil for the first time on a 1968 c10 with a 307 in it. I see it has a canister type oil filter. When I take the oil filter off, there is no filter inside and there is no O-ring. Didn't appear to be leaking oil like crazy but then again I haven't had the vehicle that long. So I go to NAPA and get a new filter and it comes with O ring. I made sure there was no old O ring left in place. Nope. It's a bit of a balancing act to fit the O ring. Can't really put it on the metal housing of the canister unless I balance it there. When I try to place the ring up into the truck, it won't stick and keeps falling down. I get it to stick fairly well and it seems like it's in place but it's in kind of a precarious position. I tighten it all up. Add oil. Start it up and now have a lake of oil on my garage floor. Shut it down immediately and begin to scratch my head. Ok so.....probably that O ring. But there wasn't one from the P.O. Hmmmm. And I don't know much about these canister filters but seems like most oil filters have many holes around the perimeter where oil goes into the filter and then exits the filter thru the main canal back into the truck. This new filter I was given has no holes around the perimeter.....rather it has many holes on the sides with solid aluminum caps on each end (except for the main channel for the oil to return to the truck. It is such a close fit (the filter into the canister ) that I can't imagine how oil could enter from the sides. Seriously thinking about one of those adapter things to go to a spin on filter. Any words of wisdom?
Ultrasummer is offline   Reply With Quote
Old 12-08-2019, 12:31 PM   #2
Ultrasummer
Re: Oil Changing Woes
Oh and btw, I would take a pic of the filter but right now it's still in place and I have a puddle of oil that is covered in that stuff to dry up spills of this nature. Next weekend I will clean up the mess, take the filter back off and take some pics. Had enough headache with something as simple as this for one weekend.
Old 12-08-2019, 12:46 PM   #3
kaycee
kaycee's Avatar
You sure you got the old o-ring out? Get a pick and make sure it's not still in there if there wasnt one in there it must of been a real b##$ to get off.Take the new o-ring and dip it in oil take a dab of grease and dab the o-ring so it will hold onto engine block.Spin the filter canister on, the oil will let it slide against mating surface,tighten to spec. Or ditch it and get a spin on conversion
2001 Silverado K-1500
2005 FXDWG stage2
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60/3:36
kaycee is offline   Reply With Quote
Old 12-08-2019, 01:26 PM   #4
Wrenchbender Ret
Your old gasket is still in there. It is old & brittle so it feels like something solid. Take out the 2 bolts that hold the adapter on & the old gasket will be easy to remove. There might even be 2 of them. After replaceing the adapter the new gasket should go in the groove & stay. Make sure they gave you the right filter. You may have one for a bypass filter like used on the 6 cyl. models & 55 V-8's. A spin on filter will be the best way to go unless you want complete originality.
George
Wrenchbender Ret is offline   Reply With Quote
Old 12-08-2019, 02:11 PM   #5
Rufas
Rufas's Avatar
Get yourself a spin-on filter adapter to replace that cumbersome canister filter.
https://www.summitracing.com/parts/prm-1134
1970 GMC 2500
700R Trans
RideTech 4 link rear suspension - Air Bagged on all four corners
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Rufas is offline   Reply With Quote
Old 12-08-2019, 02:19 PM   #6
Steeveedee
Steeveedee's Avatar
The old canister filters were very efficient but truly messy to change. I'd bet money that there is an o-ring stuck up in there, as has been mentioned. I learned that the hard way on my eldest sister's '57 Plymouth. I'd personally change to the throw-away filter and adapter, but it's your truck.
'70 Chevy 3/4T Longhorn CST 400/400/3.54 Custom Camper
"Orange Acres"
Old 12-08-2019, 03:18 PM   #7
Willys_MB
Willys_MB's Avatar
100% agree with this. It was the first thing I did when I got my truck.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is online now   Reply With Quote
Old 12-08-2019, 03:38 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
A bit late to the party but I gotta agree with the above. 55 years ago I was a kid working in a service station and canister filters were common. Also common was an old gasket being left in place (as mentioned, they can be hard to remove) and a new one added, causing a leak. Rufus has the right idea, get an adapter and enjoy changing spin-on filters.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-08-2019, 06:10 PM   #9
Ultrasummer
Ordered the oil filter adapter today. The more I think about it, I'd bet you anything you guys are right. It's probably so hard from 50 yrs it felt just like the surrounding metal when I picked at it. Looking forward to putting the new adapter on with a spin on filter. I'll let you know when I continue the mystery next weekend
Old 12-08-2019, 08:34 PM   #10
Steeveedee
Steeveedee's Avatar
No telling how long that can was on there with no cartridge in it. But those rings can get hard pretty quickly. Note that those adapters usually use a F**d part number filter. Something to entertain your parts person with.
"Orange Acres"
Old 12-09-2019, 12:02 AM   #11
Ultrasummer
Are you saying that with the adapter in place, I can't just go to the parts store and tell him I want a spin on oil filter for a 1968 C10? When I bought the canister oil filter, one of their questions was Canister or spin on type?
Old 12-09-2019, 02:29 AM   #12
Rufas
Rufas's Avatar
From the instruction sheet of the adapter from Summit I mentioned earlier:
"one of the following filters MAY be used: FramŽ HP4, Baldwin B279 or Purolator
L35132". Any of those filters will sub to any filter brand you would like to use.
Unless your set on using the correct numbered factory filter, I don't see an issue getting a filter for your truck.
1970 GMC 2500
700R Trans
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Old 12-09-2019, 07:24 AM   #13
rsavage
rsavage's Avatar
I always used grease to hold the new o-ring up in the groove and held the canister up against it while tightening the canister bolt. I've had plenty over the years and really not messier if you have a large diameter oil drain pan. But all said, the spin on adapter will make things easier for you.
1961 C1 Corvette
69 Blazer K5
2019 Ram Rebel
rsavage is offline   Reply With Quote
Old 12-09-2019, 09:41 AM   #14
maverickmk
Junior Member
maverickmk's Avatar
Oh wow, for under $20.00 that's a no brainer.
maverickmk is online now   Reply With Quote
Old 12-11-2019, 03:56 PM   #15
burb71
Active Member
I have a question for anyone that knows.
I have three 1968s, 2 trucks have the canister type filter, 1 has spin-on type.
I like the canister style.
Here is my question?
On the 1 truck that has the spin-on filter, to change it back to the canister type, do I just take the spin-on adapter off and the canister type mounts back on the block, or do I now have to get a canister filter adapter?
burb71 is offline   Reply With Quote
Old 12-11-2019, 04:10 PM   #16
Killer Bee
Killer Bee's Avatar
George
exactly! I had to chisel the old seal out of my dad's 65 c20 283..
I was fortunate find an old factory gm spin-on adapter still in the package from a seller on here..
next oil change it's getting the nos adapter
Killer Bee is online now   Reply With Quote
Old 12-11-2019, 04:13 PM   #17
Killer Bee
Killer Bee's Avatar
a little friendly advice - yer better off knowing the p/n you need before walking into a parts store these days
keep the box tabs for your maintenance items in the glove box for future reference makes even simpler..
good luck!
Old 12-11-2019, 04:18 PM   #18
Killer Bee
Killer Bee's Avatar
you'll have to peek up there to see, possible later model block would not have an adapter..
not sure what year or blocks that changed, could be yours fell in the middle of transition..
if it does have the adapter attached up there, should be able to remove it back to cart style..
maybe you and op could work out a deal for his cart kit after his is converted
good luck!
Old 12-11-2019, 04:49 PM   #19
truckster
truckster's Avatar
You mean like the parts guy who asked me if I had a diesel when I told him I needed spark plugs? (true story)
If I didn't build it or fix it, it's probably not mine.
truckster is offline   Reply With Quote
Old 12-11-2019, 04:53 PM   #20
maverickmk
Junior Member
maverickmk's Avatar
It's all fun & games until someone tries to divide by zero.
1969 GMC step side
Old 12-11-2019, 04:59 PM   #21
72c20customcamper
72c20customcamper's Avatar
I go threw it everytime with my chevelle. Goes like this, year? 66 . Model? Chevelle SS396. Engine? 496 . That's when the guy goes blank.
Mark
72 c20 custom camper Husky edition,66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark
1969 AMX ,02 Springer. 03 anniversary Fatboy.
81 Honda automatic 1600 miles
2012 Road Glide Ultra 2015 Honda Goldwing
1968 c20 stepside 1977 Suburban
Old 12-11-2019, 06:03 PM   #22
Sheepdip
Sheepdip's Avatar
good luck!
I use the "Notes" section on my iPhone...I have a separate section with a list of P/N's for all of my vehicles needs. How ever you choose save the information it it's always good to have P/N's for a equal/or that killer bee has recommended.
Sheepdip is offline   Reply With Quote
Old 12-11-2019, 06:17 PM   #23
Killer Bee
Killer Bee's Avatar
I got that box top habit from my dad.. he wouldn't use a landline much less a smart phone
mom kept all the farm business records and did all the parts ordering..
but dad would get a wild hair for something while we were in town and he had his system handy
I really like the idea of keeping notes in my phone, so long as can remember where they are
Copyright ©2000 - 2019, vBulletin Solutions Inc.
