05-16-2002, 08:54 PM | #1 |
Need wiring info,Please
Can anyone tell me how to wire in bosch relays for the head lights(wiring diagram,1 each light),to get full voltage(13-14vdc).The relays I have are Bosch and some DEI.They have 5 terminals,...85(orange),86(yellow),87(blue),87a(black)and 30(green).
Thank You for anything.Mike ------------------ 69 lwb c-10 400/350 70 lwb c-10 250/3pd Wisc.
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
05-16-2002, 09:08 PM | #2 |
Here ya go
85 - switched + source (from your headlight switch) 86 - ground (any good chassis ground) 30 - battery feed (best if run directly from the battery with a 50A fuse) 87a - + with relay off (not used) 87 - + with relay on (to headlights/foglights/etc.. ) One relay will do the trick unless you have other plans. Most headlights will pull 4-6 amps on average. Most bosch standard relays will handle 25a continous/30a burst. ------------------ '71 LWB Special options? Yes, RUST... Need some? http://www.zkast.com/display.php?file=piston/index.htm [This message has been edited by Zkast (edited May 16, 2002).] |
05-16-2002, 10:05 PM | #3 |
its all about the +6 inches
Good info. you will need the second one for your high beams. Get new hallogen lamps for the full effect.
I plan on doing this to the Longhorn. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. E-mail longhornmail@yahoo.com My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough? Columbus Ohio |
05-17-2002, 07:43 PM | #4 |
Thanks Zkast!!This is why it's great to have a board like this!Thanks to all that make it happen!!!!!!!Mike
