Old 12-06-2017, 04:09 PM   #201
vin63
It's Better With Nitro
vin63's Avatar
Re: Intro and Some Photos of my '63 Project
Checked some of my hood and bed wiring. Everything worked...phew.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-01-2018, 11:24 AM   #202
vin63
vin63's Avatar
Happy New Year! I finally got some customer stuff out the door before the end of the year, and had a little time to work on my own stuff New Year's Eve. Did some systems tests on the passenger power window install and master switch, as well as the AM/FM Stereo MP3 conversion.
Old 02-19-2018, 10:22 AM   #203
vin63
vin63's Avatar
In the throes of wiring, I thought I would do a quick test of the Ron Francis reverse relay dome/courtesy light conversion for our trucks.
Old 03-12-2018, 08:33 AM   #204
vin63
vin63's Avatar
Instrument cluster finally in:
Old 03-20-2018, 12:44 AM   #205
aotte1
Nice, what year is your Corvette? 1966.
Les
aotte1 is offline   Reply With Quote
Old 03-29-2018, 09:29 AM   #206
vin63
vin63's Avatar
Finally on for the last time.
Old 05-10-2018, 10:40 AM   #207
vin63
vin63's Avatar
Instrument lights check before wrapping up the driver side dash wiring
Old 07-18-2018, 03:53 PM   #208
vin63
vin63's Avatar
Front windshield installed. Big props to Precision Replacement Parts for the best fitting front windshield seal for the wrap-around glass.
Old 07-18-2018, 04:10 PM   #209
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
LoOKs beautiful
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 07-18-2018, 04:51 PM   #210
vin63
vin63's Avatar
Thanks! I was able to get the bed back on the next day and double checked the rear wiring harness.
Old 07-19-2018, 12:53 AM   #211
Captainfab
60-66 Nut
Looks good
Did you buy the windshield local?
Old 07-19-2018, 07:57 AM   #212
jhrusk
Cool truck
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 07-19-2018, 09:14 AM   #213
vin63
vin63's Avatar
Originally Posted by jhrusk View Post
Cool truck
Thanks!
Originally Posted by Captainfab View Post
Looks good
It's the windshield that came with the truck. I had a difficult time trying to find the door, vent, and back glass that matched the green tint.
Old 07-19-2018, 09:40 AM   #214
66-PMD-GMC
66-PMD-GMC's Avatar
Vin, the green tint is AC glass.
At least that's what I call it.
I had a small stash that I could have helped you out with at the time.
I hope you bring that truck to one of Steve''s Pontiac get togethers..
Would love to "shake a hand, make a friend."
I'm pushing to get mine done for the next one.
Projects..
440CID 2X4 Pontiac
Old 07-19-2018, 10:19 AM   #215
vin63
vin63's Avatar
I ended up getting the door, vent, and back glass from a local auto glass business...probably the same supplier for the other mail order places.
oh, man, Steve would never let me in with a Chevy truck even before his snowboarding accident. I will keep you posted when I'm out your way - I have friends in the Phoenix area and I'm looking at buying some property in Prescott.
Got the air suspension controls wired and plumbed...did a low pressure test.
Old 07-19-2018, 10:48 AM   #216
66-PMD-GMC
66-PMD-GMC's Avatar
Steve has invited me on multiple occasions and said to bring my prostreet truck...
He knows I use Pontiac exclusively.
I'm sure your truck would be welcome.
She's a beauty AND has an improved drive train.. lol ;-)
Projects..
440CID 2X4 Pontiac
Old 07-19-2018, 10:51 AM   #217
66-PMD-GMC
66-PMD-GMC's Avatar
Air looks good..
I haven't had any luck running airsprings on anything with power..
Guess I'm stuck in the static coil over generation. ..
Projects..
440CID 2X4 Pontiac
Old 07-19-2018, 11:42 AM   #218
vin63
vin63's Avatar
Thanks! This is the last time he talked to or acknowledged me (the last Pontiac Heaven event at old Speedworld Dragstrip). If my truck was a GMC, he might let me in, but even then it would be questionable.
Old 08-13-2018, 06:37 PM   #219
vin63
vin63's Avatar
The Poncho is back in the Poncho C10...finally.
Old 08-13-2018, 07:16 PM   #220
66-PMD-GMC
66-PMD-GMC's Avatar
All aftermarket pulleys and brackets?
Looks good.
Projects..
440CID 2X4 Pontiac
Old 08-13-2018, 07:32 PM   #221
vin63
vin63's Avatar
Thanks! Yeah, it's a March system that was given to me in exchange for some exhaust system welding I did for a friend after he decided to go with one of their newer systems
Old 08-13-2018, 07:36 PM   #222
cwcarpenter98
cwcarpenter98's Avatar
Dadgum, that looks good. I love that dark green. It's absolutely beautiful
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 08-13-2018, 08:27 PM   #223
66-PMD-GMC
66-PMD-GMC's Avatar
I have my motor ready to set in my C40 crew. I just need to find an affordable bell housing...
LOL..
BUT, I might just opt for the 4L85E instead. ..
I think the Lil poncho I built for this truck will do nicely.. ��
Projects..
440CID 2X4 Pontiac
Old 08-13-2018, 09:02 PM   #224
vin63
vin63's Avatar
Funny you should mention the overdrive auto transmission. This (4L80e) is what is behind my Pontiac. I think with the transmission connected to the engine while installing it was approaching 900 lbs...doing it by myself was tougher than I remember.
Old 08-13-2018, 09:11 PM   #225
66-PMD-GMC
66-PMD-GMC's Avatar
I got my 4L85E out of a 97 dually..
Has the bolt on yoke..
And they are indeed heavy..
Couldn't imagine trying to get it in with the cab and front clip on..
Projects..
440CID 2X4 Pontiac
