Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-11-2010, 04:27 PM   #1
gmcdude
gmcdude's Avatar
Cigarette lighter
Where in the fuse box does it plug in? The letters are fadded out. And has anyone bought a after market lighters, the bezel won't fit the dash hole.
gmcdude is offline   Reply With Quote
Old 04-11-2010, 05:12 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Cigarette lighter
theres a fuse box picture labeled in the faq if i were at home id post the pic leem fine it
John
1999 Toyota Tacoma 4x4
Old 04-11-2010, 05:18 PM   #3
oldblue1968chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=121515
there ya go id save it you'll use it again
John
Old 04-11-2010, 05:49 PM   #4
gmcdude
gmcdude's Avatar
Thanks I saved it, cause I could'nt find it.
Old 04-11-2010, 08:55 PM   #5
Legolas894
Chemist under the hood...
Legolas894's Avatar
Yeah-I had to bend mine a little. I've got a '67 so I just thought the hole might have been lower in later years. Check out the electrical forum for lots of stuff on this. Make sure you have the light for the cig lighter on the right spot (it will dim with the dash lights if you've got it hooked up right).
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 04-11-2010, 09:11 PM   #6
oldblue1968chevy
wuhh
Your cig. lights glows??? Mine doesnt...I must have wrong one lol.
John
Old 04-11-2010, 09:27 PM   #7
gmcdude
gmcdude's Avatar
The lighter has a red and a blue wire is one a ground?
Old 04-12-2010, 05:08 PM   #8
oldblue1968chevy
Guess mines not factory..(doesnt look it..)
John
Old 04-12-2010, 05:43 PM   #9
Dark Knight
Dark Knight's Avatar
red= +12V for lighter
blue= connect to pnl. lps. terminal
ground is provided by casing on lighter contacting the dash
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 04-12-2010, 06:55 PM   #10
Legolas894
Legolas894's Avatar
Mine is like that as well.
Current fleet:
Old 12-25-2010, 12:33 PM   #11
bosco200
bosco200's Avatar
im having a problem with my new lighter from LMC the chrome bezel seems 2 big cuz the lighter cant screw into the other part and wen i plug the lighter in it wont do anything.....i just have the red one plugged in is that wrong?
bosco200 is offline   Reply With Quote
Old 12-25-2010, 04:46 PM   #12
Legolas894
Legolas894's Avatar
Make sure there is contact between the housing and the metal dash otherwise, it won't complete the circuit. Are you sure you have power to it?
Current fleet:
Old 12-25-2010, 08:58 PM   #13
bosco200
bosco200's Avatar
Ok I got it working...but The wire for the light (blue wire) Where does it plug in at?
Old 12-26-2010, 04:57 PM   #14
oldblue1968chevy
If I understood right..the blue goes to the light for the lighter? Which would be the guages etc so that when you dim the lights, the cig lighter dims also?
John
Old 12-27-2010, 01:42 PM   #15
bosco200
bosco200's Avatar
Ok I figured it out thanks.
Old 11-27-2017, 10:28 PM   #16
andrewpclayton
andrewpclayton's Avatar
Where does the blue wire go it doesn’t have a regular connector
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 11-28-2017, 12:12 PM   #17
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Hey no. 1 fan, if it's indeed the wire for the light on the cigarette lighter you can splice it into the gray wire for the heater switch panel and the glove box light if you have one. If you touch it to the wire that goes into the back of the lighter it should light the bulb for the cig. lighter but it won't dim, and you can't tie it in there or it would be on all the time which would drain the battery in a couple of days.
The gray wire for the panel lights comes from the fuse panel at the PNl lts fuse and it feeds all the cluster gauge lights and the heater panel light as well as the glove box light if you have one.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
