Old 11-19-2018, 02:35 PM   #1
Pullski
1966 K10 Axle/Disc Brake Swap
Hey there! Iím curious as to how much fabrication is required to swap in a later (70ís and up) front axle and disc brakes into a 1966 K10? I found a decent k20 8 lug front/rear axle set with all parts (corporate 10 with warn hubs & 14 bolt rear.) I was wondering if this would pretty much bolt in to the 1966. I know thereís a forum on here about the swapping process, but it didnít mention the amount of fabrication required.
Thanks!
Pullski is offline   Reply With Quote
Old 11-20-2018, 11:11 AM   #2
First c10
First c10's Avatar
Re: 1966 K10 Axle/Disc Brake Swap
I installed a 73 Dana 44 in one truck and a 91 suburban 10 bolt. No fab work. Not sure on the 14 bolt rear. I have not done this.
Welcome to the board.
Check my build treads in my signature for swap info.
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/4.8L-ly4/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-13-2018, 03:31 PM   #3
FLATFENDER54
I did this recently. The 1973 front dana 44 bolted into my 62 k10. I had to cut the shock brackets off the old axle tubes and weld them onto the 1973 dana 44. The driveshaft bolted right up with the same u-joint.
http://www.67-72chevytrucks.com/vboa...d.php?t=773802
FLATFENDER54 is offline   Reply With Quote
Old 12-13-2018, 07:04 PM   #4
dieseldude4bt
If you use the hangers and springs from the 14 bolt to mount it you don't have to move the perches on the axle. But it's a lot of rivits to remove to mount the later hangers.
It does get rid of the tall lift blocks and bronze bushings of the original stuff.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
