04-16-2017, 11:39 AM | #1 |
Dash gauge won't move past 100 degrees
So guys my dash gauge won't move up too operating temp. I've tried ground out the gauge and it does peg out past 260, but I changed the temp switch on the side of the block and I'm still having the same issue. Anybody else run into this same issue?
04-16-2017, 12:30 PM | #2 |
Re: Dash gauge won't move past 100 degrees
I'm fairly certain the tbi v8s have two temp sensors. the dash reads off the one on the intake and the computer uses the one of the side of the cylinder head.
04-16-2017, 01:32 PM | #3 |
I thought the one on the intake went too the computer?
04-16-2017, 05:57 PM | #4 |
Side is the gauge sensor (on a 93 anyway). I have a gauge that didn't seem to read right and replaced the sensor. Still didn't read right but when I check the temp with a infrared gauge at the sensor in the head it was actually rather close. So you might want to verify the temp at the sensor
04-17-2017, 02:27 PM | #5 |
Try replacing the pigtail and a bit of the wire to the sensor in the head. The single wire can get brittle and break especially around the connector, causing no reading.
The sensor in the intake goes to the computer, the sensor in the head goes to the gauge.
Mike |
03-22-2019, 04:53 PM | #6 |
Did you ever figure this out? I’m having the same issue.
03-22-2019, 11:34 PM | #7 |
same issue for me replace pig tail and sensor gauge still sits near or around 100, but get this see if this happens to yours, turn the ignition off you'll get the true reading does your gauge peg up to correct reading middle?, this is how mine operates.
i thought the one off the side of engine block near spark plugs went to gauge? green wire.. also chevy gauges self test when starting up watch your temp gauge peg all the way far right when u turn ignition on, this is the self test prior to motor start. mine has me stumped.????? |
03-23-2019, 01:04 PM | #8 |
Moderator
Measure with an infrared thermometer.
If the gauge is accurate according to the thermometer reading the head in the same location... Low coolant? Measure the temp lower on the block... Bad thermostat? Measure the temp at the coolant neck on the intake...
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-23-2019, 04:33 PM | #9 |
If your heater is blowing hot air after 5 minutes then your getting up to temp chack your wiring from the gauge to the sending unit and if it is good consider running a cheap gauge to check and see things.
If blowing cold air after 5 minutes throw in a new 195F thermostat and a new radiator cap. Check your water pump for any seepage around the seals or lower hose for any pin holes. If you do the water pump flush out the engine you will be surprised the amount that will come out from over the years.
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
