04-19-2013, 02:06 PM | #1 |
1972 K20
72 K20 front u-joint bolt size?
Ok, So I'm ready to put my front diff driveshaft in and I can't find the 4 original bolts that go into the u-joint assy on the front of the transfer case. Anyone know the size I need to buy? I'm at work now hoping to stop on my way home to buy the bolts for the re-assembly process this weekend.
04-19-2013, 03:36 PM | #2 |
Re: 72 K20 front u-joint bolt size?
I know they are 5/16 fine thread but cannot think of the length right now
04-19-2013, 04:26 PM | #3 |
1972 K20
Thank you. I will pick up a couple lengths around 1-1/2" and longer and hope for the best. Do you think grade 5 is good enough? I will try to buy grade 8 but most places around here have limited stock
04-19-2013, 04:29 PM | #4 |
you might try an auto parts store with a good choice of Dorman products. I seem to remember they have those or off to Lowes you go and yes I think their 5/16 fine thread.
04-19-2013, 08:01 PM | #5 |
5/16x24. 3 /4" is likely IF you have the same yoke style we are talking about.
Posted via Mobile Device |
04-22-2013, 05:19 PM | #6 |
1972 K20
I purchased 5/16 NF x 1.5 long bolts but I still needed to grind off about a 1/16 to get them to fit the gap between the back side of the yoke between the transfer case. Thanks everyone for helping me out!
