Old 10-14-2011, 02:12 PM   #1
bark
drill and tap head for temp sender?
hello, who has drilled and tapped a head to install a stock temp sensor?
did some searching and never really found a how to, is there enouth room for the 3/8 pipe thread style, will I have manifold clearance? don't wanna dive in and cause myself a headache...lol
or should I just buy the adapter found online
bark is offline   Reply With Quote
Old 10-14-2011, 02:23 PM   #2
clinebarger
Re: drill and tap head for temp sender?
I drilled & tapped the head on my suburban. You will need a 37/64" drill bit, 9/16" also works.
clinebarger is offline   Reply With Quote
Old 10-15-2011, 10:43 AM   #3
bark
cool, and I assume there is enough clearance....
thanks
Old 10-15-2011, 12:58 PM   #4
C15_Sierra
C15_Sierra's Avatar
Interested in doing this on my truck...do you have to remove the head to do this?
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 10-16-2011, 01:25 AM   #5
clinebarger
thanks
Yes
No, But the engine needs to be out.
Old 10-16-2011, 09:30 PM   #6
6.0 1955
For $18 street and performance makes adapters for this. To me I'll spend that small amount to not risk messing up a head. Just contact them and tell them the thread size and sender length for mechanical gauge. They also make an adapter to replace the oil sender with a mechanical gauge system.
6.0 1955 is offline   Reply With Quote
Old 10-17-2011, 09:38 PM   #7
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
The adapters are garbage. I drilled and tapped mine on my 6.0 Do it once and do it right. Why deal with leaky cruddy adapters?
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 10-17-2011, 09:56 PM   #8
72lb4x4
A bit of searching the internet will get the P/N for a sender with the right thread, or you can get a thermostat housing from a later truck with the right size hole.
Just a few alternatives...
72lb4x4 is offline   Reply With Quote
Old 10-17-2011, 10:11 PM   #9
C15_Sierra
C15_Sierra's Avatar
During my research I found a few complaints about those senders which is why I'd been hesitant...I figured why not drill and tap, but am nervous to be drilling w/ a hand drill..
I can do that, or try to have one of the guys in the mach shop do it at work, but like I said above, I'd seen some negative reviews of sender adapters
If there are senders that have the right threads and have the right ohm range for the '91 Burb gauges I'm running, I'm all ears...did some searching and found very little info available for stock senders
-Steve
Old 10-18-2011, 09:32 AM   #10
Clyde65
Clyde65's Avatar
I used the adapter from Autometer, 12/1.5 by 1\8ths I think.
here it is.
Amazon.com: Auto Meter 2277 1/8" NPT to M12... Amazon.com: Auto Meter 2277 1/8" NPT to M12...
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-20-2011, 05:17 PM   #11
Jonce
Jonce's Avatar
When I built my 5.3L S-10, I went to the the auto parts store and bought a new sensor (brass I believe). Then I sanded down the threads enough to run the correct die over it. Once completed, I threaded into the passenger side head and hooked up my sensor wire. Worked for 2 yrs (25k miles) and then sold the truck.
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
Old 10-21-2011, 09:52 PM   #12
mcbassin
Still Learning
mcbassin's Avatar
Anyone take pictures of this modification?
Old 10-21-2011, 11:00 PM   #13
72lb4x4
Sorry, I didn't notice this was in the LS area. I was thinking about the different senders in SBC heads...
Old 10-26-2011, 06:39 AM   #14
CamaroChris
I machined a bunch of SB temp sensors down into a 12mm/1.5 thread so that means NO adapter and NO drilling and tapping the block! Talk about doing it right. If you want one PM me for details. !IF! thats OK with the board? I just need to know which sensor you want because there are like 5 diffrent connector types.
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 10-26-2011, 08:15 AM   #15
mcbassin
Still Learning
mcbassin's Avatar
That's a really great idea. I am the manager at a machine shop and make parts for my truck all the time. I should be able to modify one in a pinch. Thanks for the tip. I have also made adapters for these out of brass.
Old 10-26-2011, 09:03 AM   #16
Robznob11
Robznob11's Avatar
Some drill and tap water pump i just run a mechanical gauge sender on top radiator hose
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-26-2011, 09:15 AM   #17
bark
I never even thought about machining one down, never even considered how much extra meat was on it..... thanks I am going to take a look at it rite away
Old 11-03-2011, 10:39 AM   #18
farmtrucks
farmtrucks's Avatar
will this work in the back of passenger head and show true temp on the original gauge cluster
http://www.summitracing.com/parts/VDO-323092/
farmtrucks is offline   Reply With Quote
Old 11-03-2011, 04:28 PM   #19
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
the adapter made the temp sensor stick way out and look like crap...... so I tapped my passenger side head.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-14-2011, 06:53 PM   #20
CamaroChris
I LIKE TRUCKS
Old 11-15-2011, 02:34 PM   #21
Thealien
Thealien's Avatar
CamaroChris,
What year truck is that temp sensor for? I have a 72 and the sensors are 1/2 NPT and I couldn't find any sensors that I could turn down enough to work. Later vehicles use a 3/8 NPT with a different resistance and wil not work with my factory guages.
Old 11-16-2011, 04:42 AM   #22
CamaroChris
The picture I posted is a 91 3/4 ton temp switch. I have also turned down an 86' I'm going junk yard hopping this weekend to grab a bunch of other year temp senders to play with.
I LIKE TRUCKS
Old 11-16-2011, 10:16 AM   #23
Thealien
Thealien's Avatar
if you find any 72s that you can turn down ill take one or two.
Old 11-17-2011, 12:31 PM   #24
Chevy4Life
Chevy4Life's Avatar
I'd be willing do donate my 67 temp 1/2" npt sender for the test. the sensor end is about 13mm so, some meat would probably need to be taken off all the way down. I have no idea how much "extra" material there is or how this would effect it's operation.
I could take some basic ohm readings before and after also.
I can't believe the gauge companies haven't jumped on this. I guess the $ is in selling us gauges not senders.
Chevy4Life is offline   Reply With Quote
Old 11-17-2011, 01:47 PM   #25
Chevy4Life
Chevy4Life's Avatar
I ran across this link that uses the large block plug tapped for the 1/2" NPT sender. It's not as good as having it in the head, but it's only a few inches away. http://ls1tech.com/forums/conversion...r-adapter.html
1-Drill and tap the head
2-Drill and tap the water pump
3-Add a short pipe with a fitting in the upper radiator hose
4-Tapping the block heater/drain plug
5-?????????
6- Find or get someone to make a 12mm 72-88 Ohm Resistance At 220 Deg F sensor(If it's even possible) I've cut open a few senders and the large senders use a large wound spring and the smaller ones use a thin flat spring.
