Old 09-27-2012, 10:01 PM   #1
Breadstick
Cheap temp speedometer
I have a post-1992 700R4 transmission in my 64C10, which I assume means it takes an electical speedometer. What is a decent cheap speedometer I can get until I get the money to buy all new matching gauges?
Breadstick is offline   Reply With Quote
Old 09-27-2012, 10:05 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Cheap temp speedometer
I'm not sure there are any cheap/decent electric speedos. From the reviews I've read the inexpensive gauges are rarely worth what they cost. I'd be more inclined to study all the different brands and decide what you're going to buy when you do have the money for a matching set, and then buy just their electric speedo for now. That way you don't have to replace it later, and run the risk that the type of sending adapter may have to be changed as well.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-28-2012, 12:29 AM   #3
Captainfab
60-66 Nut
This is about the cheapest I have found.
http://www.ebay.com/itm/Brand-new-St...1d74ba&vxp=mtr
I just have not had any luck in my searching in finding out just what it takes to make that speedo operate. My next step was to send the seller a message and see if he has any info on them.
Old 09-28-2012, 12:35 AM   #4
woodscavenger
woodscavenger's Avatar
Compass app on a smart phone. I used mine for quite a while on my old dodge until I got a good feel for gear/rpm/speed patterns then just learned to flow with traffic until I got my real speedo working.
woodscavenger is offline   Reply With Quote
Old 09-28-2012, 05:23 AM   #5
T2vigil
T2vigil's Avatar
I never leave home without my Garmin. I know its no help with your question but the solution works for me until I get the new speedo gear.
T2vigil is offline   Reply With Quote
Old 09-28-2012, 07:38 AM   #6
tincan1966
tincan1966's Avatar
We used our Garmin, as well. Also was very handy when programming new speedo.
tincan1966 is offline   Reply With Quote
Old 09-28-2012, 08:04 AM   #7
Breadstick
Thanks for all the replies. I'm using Ulysses Speedometer on my phone and it works extremely well, but it kills my battery so I can't use it for a long time.
Old 09-28-2012, 02:22 PM   #8
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Wouldn't it be cheaper to buy a car charger and put in a 12volt outlet and use your phone for now?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-28-2012, 03:27 PM   #9
dougf
dougf's Avatar
That's a good idea, exactly what I would do!
dougf is offline   Reply With Quote
Old 09-29-2012, 12:18 AM   #10
Narxoleptic Customs
Been using an app for a while. Got the rpms pretty figured out...
Narxoleptic Customs is offline   Reply With Quote
Old 09-29-2012, 02:27 AM   #11
ozzyman
ozzyman's Avatar
You can buy an adapter to attach to where your cable would normally go on your transmission. It then acts as a VSS which can also be handy for cruise control if you ever go that route.
Here yah go, you can find them cheaper on Ebay BTW:
http://www.speedwaymotors.com/Auto-M...Unit,5261.html
Oh and if you don;t have a spot on your transmission for a cable hookup try something like this maybe:
http://www.jagsthatrun.com/Pages/Par...ctor-Diff.html
Active Duty Air Force 02'-Current
Proud dad of 3 girls, 1 boy and 1 TBD in Dec of 2012 - Lucky Husband
"Family owned and operated since 1969"
Dad's 66' Custom Camper - Big Family Small Budget
ozzyman is offline   Reply With Quote
Old 05-13-2016, 11:43 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
This, or something similar will still be useful even after you get an in dash speedometer.
GPS Head-Up Display Speedometer (quick and easy installation) https://www.amazon.com/dp/B005X4QCAA..._00PnxbPQZ483Q
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-30-2017, 07:38 PM   #13
LostMy65
LostMy65's Avatar
I've been using an android phone app.
It even works with an old phone that isn't tied to a carrier.
It's called DigiHUD
Old 10-30-2017, 11:07 PM   #14
rvrfoot
Gps on your phone.
rvrfoot is offline   Reply With Quote
Old 10-31-2017, 01:05 AM   #15
Backpayne
It's called DigiHUD
This is exactly what I use. You can even change it to do heads up display. Excellent app.
Backpayne is offline   Reply With Quote
Old 10-31-2017, 07:31 AM   #16
urmyboyblue
I use Speed Box- an app for my phone. Got me thru 2 Drag Weeks and a lot of regular driving. It will eat up our battery, though, quick!
urmyboyblue is offline   Reply With Quote
Old 10-31-2017, 11:45 AM   #17
ls60apache
you can remove the sensor ring from the output shaft and install a plastic gear and clip from early 700r4
ls60apache is offline   Reply With Quote
Old 11-03-2017, 02:41 PM   #18
AnobleL74
WAZE app on iPhone
will give you speed and the speed limit also of course good navigation and cop /accident warnings.
i use it alot
AnobleL74 is offline   Reply With Quote
Old 11-03-2017, 03:54 PM   #19
old cruiser
old cruiser's Avatar
I use a navman as it's easier for me rather than convert miles to klm. We have speed camera's everywhere over here
old cruiser is offline   Reply With Quote
Old 11-03-2017, 11:26 PM   #20
LostMy65
LostMy65's Avatar
Originally Posted by AnobleL74 View Post
WAZE app on iPhone
i use it alot
Yes, I almost forgot about Waze. It's also available on Android.
Old 11-04-2017, 04:29 PM   #21
luvbowties
luvbowties's Avatar
Smile Re: Cheap temp speedometer
Try & find a cheap 2nd-hand Garmin gps.......on Cr'List?
Sam
luvbowties is offline   Reply With Quote
Old 11-05-2017, 04:02 PM   #22
rvrfoot
I just put a gps on my scooter. Yes i said scooter it dont have any thang.Name:  DSCN0728.jpg
Old 11-08-2017, 04:27 PM   #23
Narxoleptic Customs
here's one that should fit in your dash.... GPS based 9cm is 3.54 inches so it should fit the hole.
https://www.ebay.com/itm/GPS-MPH-Spe...38.m2548.l4275
Old 11-08-2017, 04:28 PM   #24
Narxoleptic Customs
And here's the one my buddy is beta testing for me right now, lol.
https://www.amazon.com/ATACH-DIGITAL.../dp/B01MCXTG12
Old 11-12-2017, 02:21 PM   #25
Popcorn W
Popcorn W's Avatar
Originally Posted by rvrfoot View Post
I just put a gps on my scooter. Yes i said scooter it dont have any thang.Attachment 1705007
More info on your scooter please.
My build thread:
Project Moonshiner Bagged & Z Frame 63
http://67-72chevytrucks.com/vboard/s...d.php?t=659205
"I love the smell of grinding metal"
Popcorn W is offline   Reply With Quote
