Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-03-2019, 11:06 AM   #1
wcstory
wcstory's Avatar
Recommendations needed for epoxy primer for newly sandblasted stepside bed
I'm getting ready to have my extra long (109") longbed stepside bed dustless blasted. It has been completely disassembled for best results. I want to have everything on hand and ready to shoot before it gets stripped.
I would like opinions / recommendations on current products. It's been a long while since I was doing any automotive painting
My current plan:
Under bed supports - POR-15 2 coats and topcoat with POR topcoat (have on hand)
Bed body panels and fenders - to use U-Pol's Raptor epoxy primer because I intend to spray Raptor Liner on the inside of the stepside fenders, underside of the steps and the inside of the bed area
1966 GMC 1 Ton 305 V6 SM420 4 speed - retired Fire Dept Support Truck from Little Falls, NJ
My GMC Photos
wcstory is offline   Reply With Quote
Old 03-03-2019, 11:34 AM   #2
Kim57
Kim57's Avatar
Re: Recommendations needed for epoxy primer for newly sandblasted stepside bed
These guys make an excellent epoxy prime.
Kim
https://www.southernpolyurethanes.com/
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-03-2019, 12:06 PM   #3
wcstory
wcstory's Avatar
Kim
I've seen SPI mentioned in other threads. Have you used their epoxy products? If so, at what temps have you sprayed SPI? Reading their info they say if you cant keep the shop at 65 degrees for 24 hours don't use.
Thx
My GMC Photos
Old 03-03-2019, 01:00 PM   #4
MP&C
MP&C's Avatar
I think you would see better results out of any epoxy primer product by staying above 65 degrees. IMO SPI is just more "forthcoming" with application information like this as they would rather see you get it right the first time than have to repaint something due to adhesion failure.
As to the dustless blasting, there is no way I would use POR after media blasting anything. Use epoxy primer there as well, and have something when you're done. Too much hit or miss in using POR.
Robert
MP&C is offline   Reply With Quote
Old 03-03-2019, 10:06 PM   #5
Foot Stomper
Foot Stomper's Avatar
Pick your brand, any brand will do, but do not put anything on bare steel except epoxy primer. You can put whatever you want on the epoxy because it doesn't matter...it's mostly lipstick after the epoxy is on. Nothing protects rust creep better than epoxy...nothing.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 03-04-2019, 08:29 AM   #6
nsb29
nsb29's Avatar
Yep all of the above
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 03-04-2019, 09:03 AM   #7
Kim57
Kim57's Avatar
I make sure it's above 65 when I spray it.
It's the only epoxy primer I have ever used so can't say how it compares to others when sanding but hasn't ever been a problem for me.
Kim
My build thread
Old 03-04-2019, 09:05 AM   #8
MP&C
MP&C's Avatar
Hypothetical.... 10 years from now you go to sell the truck, and any prospective buyers are told that you used POR products on the bed supports. Half would love it, half would walk away from it. Tell the same group of people that it was media blasted and sprayed with epoxy primer, you would have a MUCH higher level of approval of the method used, a better chance of selling the truck, and as Footstomper mentioned, less chance to find rust again.
Robert
Old 03-10-2019, 09:38 PM   #9
nikwho
nikwho's Avatar
As stated above, make sure that it is 65°+, or whatever your paint manufacturer recommends. I've only had epoxy primer have adhesion issues on time, and I sprayed it at 58°, with the intention of warming the shop back up right after spraying. I applied some Rage body filler onto the hood and about a week later I could see a small crack. I picked at it a little and the later of filler came right off, pulling all of the epoxy primer right off of the metal that had been sanded with 220 grit, IIRC. I was surprised. That days temperature was the only variable between how I've applied in the past. So, I am a stickler for the minimum temperature that manufacturers reccomend.
I've been very happy with Eastwood's epoxy primer. It's made by Kirker and rebranded for Eastwood. Aside from that isolated incident where I failed to follow simple direction, it has worked very well for me!
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 03-10-2019, 09:42 PM   #10
wcstory
wcstory's Avatar
Thx. I was wondering about Eastwood’s product also.
My GMC Photos
Old 03-18-2019, 11:00 PM   #11
mikelom
Another +1 for SPI. It offers great corrosion protection and is cheaper cost wise.
mikelom is offline   Reply With Quote
