05-18-2017, 11:13 AM | #1 |
Battery Size & Factory Battery box
Hello,
I'm just wondering what you guys are running for batteries who use the OEM underfloor battery box. Rough measurements are 9 1/4" wide by 7 1/4" deep and about 7 1/2"-8 1/2" tall for the battery hold down threads. Looking for something with good CCA and wont have any problems starting a 350 with minor electrical. Pictures would also be nice to see. Thank you for your time. |
05-18-2017, 03:53 PM | #2 |
Re: Battery Size & Factory Battery box
I know a group 78 side post will fit the stock battery box. this isnt the stock location but its the stock battery box.
05-18-2017, 06:33 PM | #3 |
a lot of the starting problems actually come from poor connections or undersized wire/cable for the amp draw required.
longer run = larger wire. use good wire ends or buy good cabling that has good cable terminals. if you put the battery under the floor I would advise some remote booster lugs somewhere accessible. especially if you plan on no door handles, just some poppers. be aware of where the exhaust is running as well, especially if you have a low truck that can trap heat under the truck when parked. use a heat shield on the battery if running exhaust close. don't forget to fuse the circuits or fusible link or circuit breaker somewhere close to the battery if a long run of cable before the fuse panel. |
05-19-2017, 02:14 AM | #4 |
A stock battery is group 1
Group Size (BCI): 1 Cold Cranking Amps (CCA): 640 CCA Cranking Amps (CA): 800 CA Reserve Capacity (min): 130 Minute Voltage (V): 6 Volt Length (In): 9-1/8 Inch Width (In): 7-1/8 Inch Height (In): 9-3/8 Inch Terminal Type: Top Post This link gives group size and the measurements and if you can decode it the battery post location. http://www.batteryweb.com/bci.cfm It would be preferable to have the + post at the front next to the frame rail if at all possible. A group 35 should fit pretty good but the + post would be at the back. you for sure want the battery posts on the frame side of the battery no matter what battery you use. A group 25 might be worth looking at too.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 05-19-2017 at 02:22 AM. |
05-19-2017, 11:50 AM | #5 |
Thank you guys for the great information.
05-20-2017, 07:49 AM | #6 |
Group 35 fits perfect in my 50 3100. Conveniently, it also fits my 55 210 sedan and Kubota tractor so always have a solution for a dead battery
05-22-2017, 06:31 PM | #7 |
I generally use a Good Marine Battery Cable - as they are always Tin Coated Copper
Holds up much Better . There are several sell it By the Ft. and will even _ Put Ends on with Special High Power _Crimp Tool . . Here's 1 : https://www.westmarine.com/battery-cable |
