12-11-2017, 05:02 PM | #1 |
Rear sway bar
Good afternoon,
In an effort to improve the handling of my 86 GMC short bed I have read that a used rear sway bar from a suburban will accomplish some improvement. Does anyone have experience with such and if so what year or years suburban am I looking to find the sway bar ? Thank You |
12-11-2017, 06:30 PM | #2 |
Re: Rear sway bar
If you really want to improve the handling get the front oem sway bar . Made a big difference in my 82 . I feel no need for a rear .
I got mine at a local junk yard . The brackets on the frame are riveted . I had them off in about 20 min . Just start with a small drill bit and get bigger and hit them with a chisel . They popped right off . Last edited by homemade87; 12-11-2017 at 06:35 PM. |
12-13-2017, 07:10 AM | #3 |
Re: Rear sway bar
hello
I run a Hellwig sway bar on my rear of my 1977 GMC stepside 4x4. And you didn't have to drill any holes to install either. |
12-13-2017, 09:30 AM | #4 |
Re: Rear sway bar
Thank you,
My truck has a front sway bar I’ll probably replace the front bushing with poly Do you believe the rear bar was worth the effort and expense ? I did find a c30 rear sway bar , it appears that it won’t mount up |
12-13-2017, 12:26 PM | #5 |
Re: Rear sway bar
I just did this on my truck with a c30 rear bar. My truck is a K2500. Here is what I had to do:
I got the sway bar and u bolt mounts from the junkyard. I had to order square u bolts and CAST IRON u bolt plates ($20 each from eBay). The cast iron plates gave me a little bit more clearance around the shock mount. I still had to grind the passenger plate slightly. I also had to grind the drivers side sway bar mount plate in little bit. I bolted up the swaybar similarly as it came off the donor truck. To make it fit, I had to Cut off the excess threads from two of the U bolts. I put in all new replacement bushings. As for the end links, I used all thread and tubing along with nylock nuts. I had to drill two holes in the frame, but that was the extent of any drilling. In the end, it was a little more work than I expected, and I had to do things a little different since my truck has a 4 inch lift, but the rear sway bar was worth it in my opinion. |
12-13-2017, 01:05 PM | #6 | |
Re: Rear sway bar
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
12-13-2017, 02:30 PM | #7 |
Re: Rear sway bar
It feels flatter in turns and there is less body roll coming from the rear. On a side not (not sure if it’s related) my locker seems to have a little better manners on the street.
12-14-2017, 08:47 PM | #8 |
Re: Rear sway bar
Thank You for you input everyone
