Old 07-30-2016, 08:02 PM   #1
71k5
70 C10 SWB front wheel bearing dust caps
Just looking for a source for these dust caps; don't even know if they are original.
I've tried NAPA, Rock Auto, Advance, AutoZone, Federated, Brothers, LMC, Amazon, EBay and one Chevy dealership. Cap O.D. is approximately 2.05 inches where it fits in the rotor. Any suggestions are appreciated!
71k5 is offline   Reply With Quote
Old 07-30-2016, 08:16 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 70 C10 SWB front wheel bearing dust caps
Try searching for bearing caps ,Summit and just about any auto parts store
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-30-2016, 08:16 PM   #3
dflarsen77
Active Member
ECE has them, just search for Dust Cap. I think they're the only place I've found them too.
http://www.earlyclassic.com/catalog.aspx
Edit: just realized they're for 71-72. My 70 has 71-72 discs on it, so I was planning to use the caps from ECE, not sure they would work if your 70 has drums.
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 07-30-2016, 08:19 PM   #4
Grumpy old man
I just tried advance , bearing dust caps they have them , they don't carry dust caps
Google bearing dust caps for dozens of choices .try 2" we didn't use metrics in 71
Old 07-30-2016, 08:53 PM   #5
leddzepp
Moderator
leddzepp's Avatar
"Help" section at any auto parts store.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 08-04-2016, 09:00 AM   #6
71k5
I dug a little deeper and ordered a set of five from Amazon; if they fit, I'll send part numbers and pics.
Old 09-26-2017, 01:57 PM   #7
PaPaStewySnipes
Did that set of 5 work I am about to order, Amazon has them 5 for $5. Dorman 618-102 is the part number.
PaPaStewySnipes is offline   Reply With Quote
Old 10-23-2018, 10:03 AM   #8
pdawg
Thumbs up Re: 70 C10 SWB front wheel bearing dust caps
Old subject but I thought I'd add my 2-cents worth. I found myself in the same situation trying to find these. Dorman 13977 fit right in the hub so you just have to bend them out slightly with pliers around the perimeter to make them fit snugly. Problem solved for under $13 Canadian (eh)!
pdawg is offline   Reply With Quote
Old 03-06-2020, 05:48 PM   #9
McDeezl
Just another post to this old thread to confirm PDawg's reply with the Dorman 13977.
I came across this thread looking for the same information and after measuring and researching I figured I'd try the Dorman 13977 and picked up from Napa for $12.00.
Measured the id of the hub with the vernier caliper and it was 2.050" Measured the od on these dust caps and they came out to 2.060 .... fit was absolutely perfect just tapped them in snug fit.
Truck is a '72 GMC 1/2 ton 2wd.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=626178
McDeezl is offline   Reply With Quote
Old 03-06-2020, 08:37 PM   #10
70STOVEBOLT
70STOVEBOLT's Avatar
This is good to know, I ended up buying a pair of Mr Gasket chrome ones and lightly grinding the OD but I’m concerned that centrifugal force will cause them to come out or allow the grease to leak. I will pick up a pair of these, thank you for the info!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
2015 Silverado 1500 LS 4.3/6L80/3.23
70STOVEBOLT is offline   Reply With Quote
Old 05-29-2020, 02:53 AM   #11
BC10
BC10's Avatar
Bringing back an old thread.
I bought the Dorman 13977 caps for my 68 C10 but they were too big. Do the 68s have a smaller diameter? And if so any suggestions on what might fit? Thanks!
BC10 is offline   Reply With Quote
Old 05-29-2020, 10:22 AM   #12
70STOVEBOLT
Do you have disc brakes? These will not fit a drum hub.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
Old 05-29-2020, 11:42 AM   #13
BC10
BC10's Avatar
They are drums, so that's why they didn't fit!
Old 05-29-2020, 12:16 PM   #14
70STOVEBOLT
Quick search revealed the following but I have not used them so I cannot say for sure they will fit:
https://www.ebay.com/itm/For-1961-19...QAAOSwhqBdPV5y
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
Old 05-29-2020, 12:29 PM   #15
BC10
BC10's Avatar
Thanks! I'll contact them.
Old 06-20-2020, 10:43 AM   #16
BC10
BC10's Avatar
https://www.summitracing.com/parts/AMD-W-087
These ended up fitting perfectly
Old 05-06-2021, 11:22 AM   #17
70cst
70cst's Avatar
This is an old thread but was exactly what I was looking for. Thanks
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
