Old 10-19-2017, 09:01 AM   #1
xs-style
xs-style's Avatar
1987 k5 body mounts
So I was thinking of doing the body mounts as one of my next projects. I know after 30 years they're probably worn and anything to help the ride is a plus.... And it's a reasonably inexpensive mostly grunt work project. I thinking I'm going to run into a problem with it, so I need the benefit of yalls experience. While replacing a section of the floor boards recently I ran into two spots where the body was spot welded the frame. I know I need to lift one side of the body at a time to do the mounts, so how many spots like that am I going to run into?
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
Old 10-19-2017, 08:45 PM   #2
grillzy
Re: 1987 k5 body mounts
Where were the spot welds? There shouldn't be any spot welds body to frame. Body is independent from the frame. I will be replacing body mounts this next week and can confirm that if you like. If you were replacing floor section in the front you might have thought the floor spot welds that attach the floor to the cab bracing , that the cab braces was the frame but its not. They do look similar. If you look in one of my last posts you will see the cab brace that is attached to the body mount, it run parallel to the frame that looks the same shape.
grillzy is offline   Reply With Quote
