Old 03-14-2016, 12:40 PM   #1
Frijolito1988
Engine bay for a facelift.
Hey guys, so i finally decided to spruce up my engine bay. I never liked that my truck was so nice and painted outside compared to the engine and engine bay which did not do the outside justice. Taking the engine out was a sinch , after removing the front grill / rad support and grill took a total of about 1 1/2 hour doing the work by myself. Then degreased and powerwashed the engine bay
I had a body shop cancel the AC holes in the fire wall and paint the engine bay and chassis / outter / inner fender wells with epoxy chassis paint it is not glossy at all but per the shop it withstands grease and scratches , so we shall see.
The engine is a GM Crate engine 350/ 700r4 Combo with less than 500 miles on it so its really clean and cleaned up real easy . I always wanted to paint it Chevy orange before we installed it when i first got it but it all happend so fast it felt like the engine went straight from the tractor trailer to my truck
Taping up the engine was actually harder than it seemed, took me a good hour getting all the nook and crannys
Frijolito1988 is offline   Reply With Quote
Old 03-14-2016, 12:44 PM   #2
Frijolito1988
Re: Engine bay for a facelift.
I used VHT 500 degree Primer and VHT 500 Chevy orange enamel with 3 coats of each , 2 light 1 heavy.
Really liked how it came out , thick and glossy.
I like how it looks on the clean / painted engine bay . I dont want to install the old black rusty headers and old 80's GM Serpentine kit so im saving my pesos to buy a March Performance serpentine kit and ceramic coated headers
What do you guys think ?
Old 03-14-2016, 01:08 PM   #3
Gromit
Looks great! Nice job and IMO everyone should R&R their motor at least once.
Removing the radiator core makes things lots easier.
Regarding the headers you might be surprised what you can do with an assortment of various wire brush wheels (like say from Harbor Freight) to remove the rust and two cans of VHT paint.. My rusty old header pipes cleaned up nicely and I ended up wrapping them anyway with header wrap.
But the ceramic is better of course..
Gromit is offline   Reply With Quote
Old 03-14-2016, 03:03 PM   #4
mike16
you had me all excited there when you painted the engine pontiac blue..........but then you went with that hemi orange paint. WTF?
mike16 is offline   Reply With Quote
Old 03-14-2016, 03:20 PM   #5
yuccales
yuccales's Avatar
Looks good!
yuccales is offline   Reply With Quote
Old 03-14-2016, 03:23 PM   #6
72gmguy
72gmguy's Avatar
Looks great! Nice spring time project. Well done.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 03-14-2016, 03:32 PM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
I think you should consider another source for the serpentine setup. I have a March setup on my big block that was over $2200 and the power steering pump lasted about 500 miles and the adjuster setup for the belt is pretty cheesy. I have a thread on it in the Engine & Drivetrain section. If I had to do it over, I would go with another vendor, but at the time, March was the only system that offered the Saginaw P pump that was recommended for the steering box & hydroboost that I'm running.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-14-2016, 04:45 PM   #8
Frijolito1988
Funny you mention that. When i first bough the cans i just got it by the color did not realize they where Hemi Orange, went back and changed them to Chevy Orange, They also had Chevy Red Orange
Old 03-14-2016, 05:25 PM   #9
Gromit
Since today is Pi day (3.14) I think I can ask about your impressions of the lift plate..
Since you got the motor in and out okay yours was a good test to prove it did hold the entire weight of the motor and trans; but I think it may have been close..
I got curious about this after seeing your photos - Here is the calculation for the pull-out strength of those four 5/16-24 manifold bolts as best as I can tell:
pi x Pitch Diameter x % thread x length of engagement x shear strength of material.
So for example:
3.1415926 x .3125 x (((.3125-.2716)/.01299))/100) x .5 x 28,000psi = 440 lbs per bolt x 4 = 1,760 lbs x 50% safety factor = 880 lbs.
I'm guesstimating the weight of your motor and trans at 750 to 800? So if you go over any bumps with that motor hanging from the lift it seems to me it might go over the 880. But maybe that is in the safety factor..
By pull-out meaning by shearing the female threads in the aluminum manifold at the thread roots.
28,000 psi being the yield strength of cast aluminum AA but there are so many alloys it is hard to say.
The .2716 is the size of the letter "I" drill used before tapping the 5/16 bolt holes in the manifold.
But I don't want to hijack the thread so just mean this as food for thought for next time you pull that motor!
Old 03-15-2016, 06:10 PM   #10
Frijolito1988
So for example:
Yikes! Something to think about next time lol
