08-24-2017, 09:46 PM | #1 |
Help identify ports on Edelbrock 2116 intake manifold
Looking for some help since the Edelbrock manual was awful. It doesn't even identity the thread and pitch on some of these holes. You just gotta figure it out.
I have two pictures outlining some ports that I've closed up for now until I know what they do. I'm trying to identity the ones I need to put something in, what it does, and if I need it. I'm assuming there is cab heater in and out and water temp sensor. Not sure which is which. TIA Front view Top view
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
08-24-2017, 10:51 PM | #2 |
Hollister Road Co.
Re: Help identify ports on Edelbrock 2116 intake manifold
1. Water pump bypass hose outlet
2. water pump bypass inlet 3. vacuum port for what ever 4 & 5. water ports for what ever. one side of the heater the other side of the heater would need to be on the water pump water pump bypass is seldom use anymore you could use Port 5 and 2 for the heater ports are either 3/8 NPT or 1/2" NPT |
08-25-2017, 08:04 AM | #3 | |
Here is a shot of the carburetor which is also not very well documented. Can you help identify the ports? I believe 6 and 8 are vacuum advance ports, but they are facing away from the HEI. I'm also not convinced I even need to hook up the vacuum advance on the HEI. I fired up the engine without it the other day. The site says vacuum advance helps fuel economy at cruising. I seriously doubt how much "efficiency" I'd get out of a little extra puff of air in a V8 lol. What I can't figure out is if one of these ports is the fuel return.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride Last edited by gigamanx; 08-25-2017 at 11:10 AM. |
08-25-2017, 08:14 AM | #4 |
Ok, found some answers on the carburetor...
6 is for automatic transmission? Although my 700r4 doesn't have anything that looks like a vacuum tube. 7 is PCV valve 8 is timed vacuum advance 9 is for power brake booster This was a good write up of the ports http://www.cjponyparts.com/mustang-e...uctions/a/334/
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride Last edited by gigamanx; 08-25-2017 at 11:11 AM. |
08-25-2017, 04:10 PM | #5 |
I have an Edelbrock Air Gap and used #4 for my temp sensor.
