04-24-2018, 11:22 AM | #1 |
CPP Combo Valve-to-stock brake line adapter fittings
Ok, I need help from the guys who have done this before.
Doing my disc brake conversion, using a CPP combo valve and my stock brake lines, the front brake line appears to be larger than the hole in the combo valve, and the rear appears to be smaller. I figured Im looking for: Front: 3/8" x 24 male inverted flare to a 7/16" x 24 female inverted flare Rear: 9/16" x 20 male inverted flare to a 1/2" x 18 female inverted flare Sound right?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC Last edited by demian5; 04-26-2018 at 06:18 PM. |
04-24-2018, 12:35 PM | #2 |
Moderator
Re: CPP Combo Valve-to-stock fuel line adapter fittings
Cpp should have the necessary adapters. When I did mine they sold a package containing 3 different ones. They were the only place I could find the proper sizes, no auto parts store or fastener shop had the proper size.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-24-2018, 12:55 PM | #3 |
I seem to recall my CPP combo valve coming with the set of adapter fittings.
04-24-2018, 01:47 PM | #4 | ||
"I ain't nobody, dork."
My stock brake lines matched right up to the CPP combo valve. But my rig is a 1972... so that might have had something to do with it.
Gary
04-24-2018, 01:50 PM | #5 |
Found on the site.
PROP VALVE FITTINGS CP2091 9/16"-18 inverted male flare, 3/8"-24, 7/16"-24, 1/2"-20 inverted female, kit $10.00 Pretty much what I thought. Ill cruise to a hardware place and get them.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
04-24-2018, 01:59 PM | #6 |
Moderator
That’s the one. Good luck finding them anywhere else. I even went to McFadden/Dale, which carries everything under the sun...and they didn’t even have them.
04-24-2018, 02:42 PM | #7 | |
Grainger next door says they have them on the website. I actually found them at Autozone last night but didn't like the fit. Worse case im driving to CPP at lunch tomorrow to get the set.
04-25-2018, 05:57 PM | #8 |
Drove to CPP they had the adapter in a set of 3 (for 3 different sizes) for the rear brake line (it is steel). The front I had to source myself, and it is brass from Pep Boys.
04-26-2018, 06:17 PM | #9 |
Got it installed, now on to the ball joints before the installation of the brackets and the brakes.
