Old 02-22-2017, 07:19 PM   #1
LSSierra
Fuel Switching valve???
So after reading multiple threads about using the High PSI fuel switching valve for my duel tank LS Swap, apparently JC Whitney doesn't carry part number ZX812705U anymore. And I can't seem to order it from Pollak direct. Anyone help a brother out here?
Do I get the 3 valve or the 6 valve? Motorized? Most importantly, where do I get this nowadays?
I'm swapping into an 87 Sierra, using all the suggested pumps etc and trying to keep the dual tank setup so I need the switching valve to handle the higher PSI.
Thanks in advance!!
-1987 GMC Sierra Classic 5.3 LS -
-2001 Toyota Camry 175k -
LSSierra is offline   Reply With Quote
Old 02-22-2017, 07:54 PM   #2
SC_Titan
Re: Fuel Switching valve???
Pretty sure you need the 6 for efi. Seems like a member on here sells the correct valve and upgraded wiring as a kit. Gmachinez or something like that.
SC_Titan is offline   Reply With Quote
Old 02-23-2017, 12:20 AM   #3
El Dorado Jim
autozone has the valves
El Dorado Jim is offline   Reply With Quote
Old 02-23-2017, 01:59 AM   #4
gmachinz
Yep-I have them in stock....NEW 65 psi 6-port valves for use with EFI swaps-$75 shipped for the valve in the US!
gmachinz is offline   Reply With Quote
Old 02-23-2017, 02:40 AM   #5
gmachinz
Here's a complete LSx/EFI swap harness for dual tanks and a 65 psi valve, which is included here. $309 for everything you see. Not pictured but included is the correct on/on rocker switch for the selector switch on the dash.
Old 02-23-2017, 07:57 AM   #6
LSSierra
Gmachinz - PM sent. Thanks all.
Old 02-23-2017, 12:57 PM   #7
kdh454
Just in case it helps anyone, most, if not all, late style 3 port valves are simply 6 port valves with 3 ports plugged. When I ordered mine, the 3 port was significantly cheaper and all I had to do was remove the three caps to make it a 6 port valve.
kdh454 is offline   Reply With Quote
