Old 03-14-2019, 06:35 PM   #1
Magicalzoomer
1965 C20 SBC 350 and TH350 Swap Item List/ Questions
Hi Guys,
First of all, sorry in advance if these are really novice questions, but any advice will go a really long way for me.
I am planning on swapping my 283 and 4speed manual for fresher 350 and TH350, mostly because the current setup will not allow me to go more than about 55MPH without revving too high and I believe there is currently a rear main leak, so the transmission will have to come out anyway. This will be my first ever engine swap and I was hoping to learn from your expertise.
FIT:
First of all, I attached pics of the motor and tranny that I am putting in 350motor/TH350 2wd Tranny. What should I check for to make sure that these will:
1. Match Together?
2. Fit into the C20?
3.Require Driveshaft to be cut?
PARTS NEEDED:
After some Research Here is what I am Figuring the parts I will need. Please feel free to add.
Items Needed
1. Transmission Crossmember
https://www.performanceonline.com/19...n-Crossmember/
2.Floor shift Kit
https://www.speedwaymotors.com/Lokar...xoCEmkQAvD_BwE
3. Any of parts Needed or Helpful?
ADDITIONAL GUIDANCE AND INFO:
4. Any tips and tricks to make this go smoothly?
Really thank you a ton for your help with this. This truck is my first build and I want to work to make sure that it is worthy. I really appreciate any guidance for a beginner like me.
Magicalzoomer is offline   Reply With Quote
