Old 08-21-2011, 07:27 PM   #1
67 DREAMING
Ring gear id numbers
I have some numbers maybe you guys can decode for me i have a 1991 chevy 4x4 z71 trying to determin the gear ratio the id tag in the glove box is obliterated and caint tell what anything says on it so i dropped the cover on the rear end and heres the numbers that i found on the ring gear 3984831 12 41 g.m.k
67 DREAMING is offline   Reply With Quote
Old 08-21-2011, 08:23 PM   #2
gmtec93c1500
Re: Ring gear id numbers
if you got the cover off count the teeth on the ring gear
gmtec93c1500 is offline   Reply With Quote
Old 08-21-2011, 10:37 PM   #3
loudnlifted88
loudnlifted88's Avatar
type your vin number in the box on http://www.compnine.com/vid.php, that will give you every option your truck had from factory
IM ONLY 18 AND LOVIN IT
IF MUD AINT FLYIN YOU AINT TRYIN!
1badgmc- Just think. Someone worked hard to make it look that bad.
1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383945
1994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438873
1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build
1998 GMC K-1500 ECSB 305 auto partd truck
1999 GMC K2500 suburban 350 4x4 Dads project
1981 Corvette 350 auto Also Dads project
1989 Corvette 350 auto ^^
1998 GMC K1500 ecsb 305 auto Brothers project
loudnlifted88 is offline   Reply With Quote
