Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-31-2022, 08:17 PM   #1
eodcoduto
1972 C60 Master Cylinder size help
I can find most answers to my questions with the search function and Googling stuff, but I am stuck on this. I have a '72 C60 that is about back on the road, rebuilt the 366 and now I am working on the brakes. The master cylinder is shot, a rehone didn't help and I can't find a rebuild kit anywhere, so I am ready to get a new one. Now the issue is the master cylinder that I took off is a 1.5" bore, which should be right for a F070 7,500lb front axle, but I also have the 9000# spring option with a 23,000lb rear axle. So should this have the 1.75" bore master? Here is my RPO sheet, and any help is appreciated.
This is a 55K mile truck without rust and it is getting put back to work hauling bales and wood chips.
eodcoduto is offline   Reply With Quote
Old 08-05-2022, 12:08 PM   #2
eodcoduto
Re: 1972 C60 Master Cylinder size help
I found the master cylinder and things are bled properly now, but the hydrovac isn't working so I am searching for a replacement.
Old 08-06-2022, 01:53 AM   #3
Bob B.
Is it a dual unit? If so, take a look at a NAPA NBB518009.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 08-06-2022, 04:55 PM   #4
eodcoduto
No its a single unit, I am sending it to Cardone for and R&R on Monday. New wheel cylinders will go in as well so other than a couple of hard lines the brake system will be new.
