09-09-2023, 12:24 AM | #1 |
parking brake cable recomendation
for those of you who have done rear disc conversions using the caddy e brake calipers... what length brake cable did you use? I measured roughly 50 inches from the caliper to the cable hanger clip on the frame. is there a specific type cable that works better?
09-13-2023, 09:33 AM | #2 |
Re: parking brake cable recomendation
I will jump in here too for information. My rear brake is the Camaro kit offered on here.
I don't want to hijack this thread but maybe it is the same info? I am sure somebody has done this and completed the final piece. Thanks, Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-15-2023, 12:52 PM | #3 |
BMW & ASE Master Certified
When I did the rear c5 brakes swap on my truck, I looked on rock auto, bought the oem cables for the caliper application and shortened them myself to fit the stock c-10 intermediate cable, then sent the cables off to i believe it was https://push-pull.com/custom-cables-brakes/
and they simply put a new crimped on end for the cable. while its not off the shelf, it was cheap and a very simple solution. clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
10-16-2023, 04:38 PM | #4 |
Collecting the parts right now for my setup and have the Cadillac calipers on my 66. Info I found on POL was that the cable housing length is 34.7” and cable length is 43.6” for the conversion cables. The part number on POL is EBC6387X, 2 cables are $103 so I am still looking for another option. Dimension of the cables that were on my truck are housing 30.5” and cable is 40.25”. They are just a couple inches too short for me to hook to the caliper.
12-16-2023, 08:22 AM | #5 |
On my 67 with a 9.5 14 bolt I used Camaro rear disc. I used the Camaro cables from Rock auto. Placed/fitted the frame mount then used the cable couplings from Rockauto. If I had to do again I would just leave the drums. But for the intermediate cable I used 1/8 inch stranded cable (TSC), drilled an eighth inch hole in about 1/2 inch length of 5/16 inch solid rod. Squeeze them with a crimp tool then put a hot mig spot on the ends.
Turned my orig emergency brake into a parking brake. To pass Texas inspection I had to depress brake pedal then apply hand brake lever to pass in gear idle.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 12-16-2023 at 09:01 AM. Reason: pic |
