Old 02-27-2011, 03:04 PM   #1
rahatawa
rahatawa's Avatar
64 Fuse Block
Turns out I need a new alternator. So after that is done I need to get the fuse block mended as well. From the picture it looks like I am missing a fuse clip on the bottom. Is there anywhere to get a replacement? Second problem. Nothing is connected!??? Does anyone have a picture of of their block? I am going to have to crawl under there and start fishing for wires. The only other wire i found was a black wire with alligator clips on both sides? not sure where it came from. All the wiring looks original and in tact. I am guessing the previous owner pulled all the wires from the fuse block shortly after the alternator went out.
rahatawa is offline   Reply With Quote
Old 02-27-2011, 03:39 PM   #2
lakeroadster
Re: 64 Fuse Block
I think you are ok-as-is, as I see it and your fuse box looks just like '65's.
The last "fuse" is for the tail lights / dome light.
Under that is a plug in connection for a spot light, you don't have one, therefore there is nothing there.
Again, as I understand it, that's the deal.
I hope that helps...
lakeroadster is offline   Reply With Quote
Old 02-27-2011, 10:15 PM   #3
rahatawa
rahatawa's Avatar
Re: 64 Fuse Block
The last "fuse" is for the brake lights / dome light.
So the spade terminals next to the heater and radio fuses don't need wires?
Old 02-28-2011, 09:10 AM   #4
lakeroadster
Re: 64 Fuse Block
Here is a photo of my 1965 C10 fuse box for comparison.
Old 02-28-2011, 10:21 AM   #5
rahatawa
rahatawa's Avatar
Re: 64 Fuse Block
Thanks! Yeah It looks like I am in good shape. Thanks a Lot!
Old 02-28-2011, 08:57 PM   #6
dracko
dracko's Avatar
Re: 64 Fuse Block
Slightly off topic, but if a truck didn't come with a radio from the factory would the underdash harness still have the plug for one? or can you buy them seperately?
dracko is offline   Reply With Quote
Old 02-16-2012, 11:15 PM   #7
Bamer36
Bamer36's Avatar
Re: 64 Fuse Block
is this the same box that goes for a 1963
Bamer36 is offline   Reply With Quote
Old 03-17-2012, 08:47 AM   #8
fasteddie1964
fasteddie1964's Avatar
Re: 64 Fuse Block
Does anyone sell a new fuse block like these? My terminals have gotten rusty and sometimes don't make a good contact.
Friends don't let friends drive Fords
fasteddie1964 is offline   Reply With Quote
Old 04-14-2018, 08:02 AM   #9
J Williams
J Williams's Avatar
Re: 64 Fuse Block
So I have a question as well. I have a wire coming out of the B. U. LPS. This is a brown wire. Where does it go? My best guess is backup lamps but I don't have any on the truck ??
63 C10
J Williams is offline   Reply With Quote
Old 04-14-2018, 08:03 AM   #10
J Williams
J Williams's Avatar
Re: 64 Fuse Block
I have a 63 and mine is identical
63 C10
Old 04-14-2018, 12:23 PM   #11
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 64 Fuse Block
They do, contact:
http://www.wiringharness.com/
Their catalog - http://www.wiringharness.com/PDFS/TR...hevy_Truck.pdf
Good luck.
Old 04-14-2018, 04:17 PM   #12
Rac65
Re: 64 Fuse Block
I have everything working except instrument panel lights. I have no power on either side of the fuse. I turned the fuse panel around and don't see anything broken or disconnected. What am I missing?
Rac65 is offline   Reply With Quote
Old 04-14-2018, 04:56 PM   #13
ray_mcavoy
Re: 64 Fuse Block
Power for the instrument panel lights first goes through the "STOP TAIL DOME" fuse, then through an orange wire to the headlight switch. From there, it passes through a rheostat (variable resistor) that is used to adjust the brightness of the panel lights by rotating the headlight switch knob. After leaving the headlight switch, power goes through a green wire that takes it back to the "PANEL LTS" fuse in the fuse box. Finally, a gray wire runs from the other side of that fuse to the panel lights.
Since you don't have power on either side of the PANEL LTS fuse, the problem is most likely in the headlight switch rheostat. They have a tendency to get dirty / corroded and no longer make good electrical contact. Sometimes simply rotating the knob back & forth a few times will scrape off some light corrosion and get them working again. You could also try spraying some electrical contact cleaner on the rheostat portion of the switch (it's the part that looks like a coiled wire near the knob end of the switch). But if that fails, you'll probably have to replace the switch.
Note that if the problem were farther "upstream" in the circuit it would likely affect the brake lights, tail lights, and dome light too.
ray_mcavoy is offline   Reply With Quote
Old 04-14-2018, 06:40 PM   #14
The Rocknrod
Moderator
Re: 64 Fuse Block
Rheostat.
Old 04-14-2018, 10:49 PM   #15
Rac65
Re: 64 Fuse Block
Thank you for the help.. I will try to check it tomorrow. The truck has been off the road since the fall of 08. I am so ready to drive it again.
Old 05-01-2018, 08:12 PM   #16
jeff_wilson70
jeff_wilson70's Avatar
Re: 64 Fuse Block
I believe that goes to the heater switch
jeff_wilson70 is offline   Reply With Quote
Old 05-02-2018, 04:50 AM   #17
stsalvage
Scrapper 1
stsalvage's Avatar
Re: 64 Fuse Block
I feel if some one has hacked up harness that bad.Me i spend the 399.00 for a brand new fuse box and under dash harness.To me I did mine 12 years ago spent 599.00 for everything.And not one problem never left me on the side of the road
stsalvage is offline   Reply With Quote
Old 10-12-2019, 11:36 AM   #18
spspspspoon
Re: 64 Fuse Block
B.U. Laps
Back Up Lamps
spspspspoon is offline   Reply With Quote
