Old 03-17-2018, 11:07 PM   #1
Flying Hamster
Flying Hamster's Avatar
Blower Resistor....
Killed yet another blower resistor.
What ever possessed the designer to put it IN the air plenum, at the low spot, where condensation builds up? Especially in the winter, when you run the defroster all the time, which runs the A/C, which makes it worse.
Seriously? It needed to be at the lowest spot?
2006 Sierra RCSB V6 5 Speed RWD.
Flying Hamster is offline   Reply With Quote
Old 03-18-2018, 06:12 PM   #2
MASONGMC
Re: Blower Resistor....
Gm had a safety recall for some of those truck could cause a fire.
MASONGMC is offline   Reply With Quote
Old 03-18-2018, 08:12 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
They aren't covered anymore. GM extended the warranty to 10 years/150,000 miles for the resistor and the wiring. All of the trucks affected are older than 10 years old now.
95 S_Trucker is offline   Reply With Quote
Old 03-20-2018, 01:31 PM   #4
Desert1957
Desert1957's Avatar
FYI make sure and check the wring pigtail for any signs of discoloration which means overheating and burnt connectors. This will add resistance to the circuit and burn up even a new resistor.
Desert
Desert1957 is offline   Reply With Quote
Old 03-22-2018, 06:17 PM   #5
homemade87
I ordered a kit which included the connector . You have to splice the wires together but it will give you a new connector as well . Seems like it was a dorman and has worked for quite some time with no problem .
homemade87 is offline   Reply With Quote
Old 03-24-2018, 08:25 PM   #6
Flying Hamster
Replaced the pigtail a couple resistors ago. The Dormans don't last any better than any others. Problem is condensation. The resistor is in the lowest place in the plenum, and water builds up and shorts it out. I tried making a spacer that had a couple small gaps to let the water out but it whistled horribly.
