Old 01-12-2024, 05:50 PM   #1
pdxhall
pdxhall's Avatar
long bed problem
I have a 66 long bed fleetside that I'm putting a new bed in. I need a big favor from the long bed owners. I need some real good pictures of the front of the bed that shows the position of the front mounts. I would like both finished beds and unmodified frames. I need to verify the frame mount position. I'll explain more later. Thanks
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-12-2024, 07:13 PM   #2
bigmoe
bigmoe's Avatar
Re: long bed problem
Does this thread help?
https://67-72chevytrucks.com/vboard/...&highlight=bed
bigmoe is offline   Reply With Quote
Old 01-12-2024, 11:40 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Not sure if these pictures are close enough to help, but it's all I have for the moment.
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 01-13-2024, 01:18 AM   #4
pdxhall
pdxhall's Avatar
That bare frame photo is close. Do you happen to have any more of that frame? I have the 2 front bed to frame mounts on each side that are 12" apart that hold the front cross sills that bolt to the bed and then a dummy cross sill at the front end of the wheel houses. I have been told that this is not correct for a long bed fleetside so I am trying to verify that this is correct since he won't believe me.
Sanity'66
Old 01-13-2024, 01:41 PM   #5
bigmoe
bigmoe's Avatar
Here's some pics of a short fleet.
https://67-72chevytrucks.com/vboard/...t=crossmembers
Old 01-13-2024, 01:49 PM   #6
bigmoe
bigmoe's Avatar
Here's a long box:
https://67-72chevytrucks.com/vboard/...ght=cross+sill
Old 01-14-2024, 10:16 PM   #7
cwcarpenter98
I'm not sure who told you that, but he would be incorrect for a long bed. I no longer have that frame, but I have some old pictures of when I redid the bed wood on my 63. It'll be the same as your truck. I forgot I had these pictures way back in the files.
Ignore the blue circle, I don't remember why I circled that
For a long bed, there's 3 full bed to frame crossmembers in front of the wheel wells that bolt the bed to the frame. There is a short crossmember that does not bolt anywhere to the frame, but it does tie the front of the wheel tubs together and provides an additional crossmember for bed bolts. The rear of the wheel tubs bolt into a full bed to frame crossmember.
Christian Carpenter
