08-31-2017, 10:58 AM | #1 |
C10 Club Tennessee
Do I need a different oil pan?
Getting ready to install an LS in my 87 squarebody. Not sure if I can get away with using this oil pan. Truck is lowered 5/7. In my 71 burb I had to change the pan, but wanted to ask before I sit it down inside the truck.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
08-31-2017, 11:23 AM | #2 |
Re: Do I need a different oil pan?
It's most likely going to hang down just as much in an '87 as it would have in your '71. If the truck wasn't lowered it would be fine, but since it is, I would at least consider the GM muscle car pan as they're dirt cheap and with the right mounts should put the bottom flush with the crossmember.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-31-2017, 03:07 PM | #3 |
Depends on the tire size you run, what engine mounts you use, what ground clearance you're comfortable with, etc. It will sit an inch or two below the bottom of the engine crossmember.
08-31-2017, 06:17 PM | #4 |
meowMEOWmeowMEOW
IMO with most the setups guys on here are running, you'll want to replace it unless its a stock height truck.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-31-2017, 06:25 PM | #5 |
my engine came from a escalade and I'm using the stock LS pan in my non lowered 81....its exactly the same level as my crossmember...doesn't hang below it..
08-31-2017, 09:50 PM | #6 |
I would say you definitely need a shorter pan.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-31-2017, 10:43 PM | #7 |
My 5.3 in my 68 sits about 1/2" above the crossmember using a "F" body oil pan (98-02) and the sump is still above the bottom of the crossmember. I used the organ donor 2001 ls mounts and made my own mount brackets to get the engine as low and to the rear as possible. I like to fab things up sometimes. The bottom of the "F" body oil pan is basically at the same plane as my 4l65e oil pan is.
I believe using dirty dingo adapters and 68 style mounts position tilt the motor up in the front from what i can tell looking at many install photos. Nothing wrong with it but my objective was to get it low and rearward with some fab work. The f body pan is the thinnest of any pan out there at i believe 1.25". My steering center link in the straight ahead position is so close i can barely get my pinky between it and the oil pan. Sticking my head under the front bumper and looking rearward i have no low hanging fruit, even my exhaust is tucked up including my exhaust "X". |
08-31-2017, 10:47 PM | #8 |
C10 Club Tennessee
09-02-2017, 09:26 PM | #9 |
I would say you need a shorter pan. I went with the CTS-V pan. Improved Racing has the best price on the complete pan swap.
BTW... those headers look awesome! What are they???? |
09-03-2017, 01:06 AM | #10 | |
C10 Club Tennessee
http://www.ebay.com/itm/C-10-LS-Chev...53.m1438.l2649
09-14-2017, 08:27 PM | #11 |
C10 Club Tennessee
Can you guys post a link to a pan that will work? Do the muscle car pans work? I can't tell if they are any different than the the pan I have on it now.
09-14-2017, 09:31 PM | #12 |
In my build thread all the part numbers are listed
09-14-2017, 09:45 PM | #13 |
Proud Vet that loves the USA
Like others have said, change that pan. My son's truck had that pan with a 5/7 drop. he scraped it a few times...and I was always concerned. Better do it now while its easy. Once its in the truck its won't be.
Bubba |
09-28-2017, 08:34 AM | #14 |
Bryan, with as low as your squarebody is, i'd get a new pan. I've got the GM Muscle Car pan from Jegs for $200. The Holley pan is nice too for $300.
09-28-2017, 03:47 PM | #15 |
The muscle car pan is only .75" shorter than the truck pan. Not worth the expense in my opinion. The CTS-V or the F-Body is a much better option.
09-28-2017, 07:40 PM | #16 |
Like some others have said the CTS-V works best. - Part Numbers -
Oil pan: 12631828 Pickup tube: 12621299 Windage tray: 12611129 Dip stick: 12584737 Dip stick tube: 12584738 Pickup tube o-ring: 12557752 Gasket: 12612350 |
04-16-2018, 08:53 AM | #17 |
Still Learning
Has anyone used this kit from Summit racing?
https://www.summitracing.com/parts/nal-19212593 |
04-16-2018, 10:01 AM | #18 | |
04-16-2018, 11:27 AM | #19 | |
Still Learning
What motor mounts did you use on your swaps? I am using the clamshell style with mine. Right now my pan hangs below the crossmember about 1-3/4- 2". |
04-16-2018, 08:04 PM | #20 |
I made my own mounts, so that a truck pan is only about an inch below the crossmember, which put the muscle car pan flush. If you're that far below ir, then the muscle car pan may still hang down 3/4" or so.
04-16-2018, 10:17 PM | #21 | |
Still Learning
thanks for the help. |
04-17-2018, 04:14 PM | #22 |
The F-body oil pan is currently $179.00 at Advance Auto. I plan on starting my swap when I return from Pigeon Forge the weekend and this is the pan I'm using. Keep in mind, this is just the bare pan but I think the price is pretty close to or cheaper than a CTS-V. The muscle car maybe cheaper but the F-body GMP77A is shorter. I know a couple of guys with '87 LS short beds and I think the stock pan is absolutely to low for a lowered truck.
04-18-2018, 01:26 AM | #23 |
C10 Club Tennessee
Don't get suckered into a lower price with just the pan. You're going to need the pickup tube and windage tray. Some times you can modify your current windage tray.
04-23-2018, 01:15 PM | #24 | |
Still Learning
Is that not the case? |
04-23-2018, 03:48 PM | #25 |
That's my understanding. There is a change up number on the tray somewhere along the line but when I bought my CTSV parts which are not installed yet I didn't buy the tray expecting I'll use my truck one.
Saskatoon, Saskatchewan Canada |
