02-16-2017, 05:08 PM | #1 |
Rear lower quarter panel
Does anyone know if they sell just the rear lower sheet metal? Do i have to buy a fleetside lower and make it work? The tub i bought had them removed for im guessing a tube or plate bumper.
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
02-16-2017, 05:16 PM | #2 |
Re: Rear lower quarter panel
The section in red. I need both sides
02-16-2017, 05:32 PM | #3 |
Nope !! That was the only thing I couldn't get, because the shape of that area is unique to the Blazer. Thankfully my 1/4's were in good shape at the rear of the truck. I used fleetside patches to fix the wheel arch , and they fit pretty good with a bit of massaging.
02-16-2017, 11:53 PM | #4 | |
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery Last edited by 69-72; 02-17-2017 at 12:06 AM. |
02-16-2017, 11:58 PM | #5 |
If you can try looking for patches from a truck, original metal instead of repro, it will be alot easier to fit. Long or shortbed will work, just with the long bed you can't use the whole piece to the end because it will be longer. Shortbed will be the same length as blazer but the chances of finding a short bed patch from a truck are obviously much slimmer.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
02-17-2017, 11:11 AM | #6 | |
http://www.autometaldirect.com/image...067-3R_800.jpg https://s-media-cache-ak0.pinimg.com...b7fc5954d8.jpg Regardless, that part is not available aftermarket, only the long box patch panel is. Last edited by hemi43; 02-17-2017 at 11:26 AM. |
02-17-2017, 11:22 AM | #7 |
Yes it is the same. The pictures I posted were of a short bed side fitted to my jimmy. That is correct, as far as I know the lower rear is not available in short bed length, only long bed. Often times only the piece directly behind the rear wheel is what is needed, not the entire length. Another thing that could be done if the entire length is needed is to take a section out of the middle of the long bed patch and weld it back together.
02-17-2017, 11:35 AM | #8 | |
When I did my Blazer, I also bought the long box patch panels, but never used them because they would have taken too much massaging to make them fit. Not only was the rear part a different shape, the taper from front to back was way off. I opted to use a full wheel arch because thankfully my 1/4 was not that bad at the rear. |
02-17-2017, 11:40 AM | #9 |
That's the reason why I stick to original steel whenever I can. I have learnt that lesson the hard way too many times over the years about ill fitting aftermarket. Although I must say I was impressed with the short bed side I got. The detail was nice and everything lined up perfectly.
I wish I could say the same about the repro blazer bedside. I made a post about it here but long story short it was a disaster. I will find the link and post it. Edit. http://67-72chevytrucks.com/vboard/s...9&postcount=55
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery Last edited by 69-72; 02-17-2017 at 11:59 AM. |
02-17-2017, 12:11 PM | #10 | |
02-17-2017, 12:11 PM | #11 |
So really i will want to look for someone parting out a blazer... which rarely happens. I have seen some that were practically swiss cheese been resurrected :/ Oh well ill just have to keep my eyes peeled! thanks fellas
02-17-2017, 12:22 PM | #12 |
Or go the shortbed route but at $400ish per side it wouldn't be very practical for the small section you need. Good luck either way 😊
