Old 11-22-2019, 09:22 AM   #76
Andy4639
Old member
Andy4639's Avatar
Talking Re: Daughters 68 step...
Originally Posted by BigBird05 View Post
Thanks for the measurements guys! Now I know where to move the trailing arm cross member too. On the blueprint sheet the 0 line is the front of dash. All measurements are taken from this point. Forward( to the front) backward ( to the back).
All my measurements came off the back of the cab to rear of the frame. Both over all measurements where 75" so at least I know my cab is square!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-22-2019, 09:24 AM   #77
Andy4639
Old member
Andy4639's Avatar
Originally Posted by Getter-Done View Post
Andy
I have been informed that EZ grind wire is the real deal.
I will refrain from using that (P) word
Pro that is.
I purchased some from my Local welding supply store.
I got it at a good price.
It's a little bit higher on e__ -Bay
I have not used it yet.
Because I am not to that point yet.
This is just a Suggestion.
This throwing that out there / .
Yea don't like throwning that P word around a lot. I've been working on these trucks for over 30 years and I wouldn't call myself a pro by any stretch!
Old 11-25-2019, 08:10 PM   #78
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Daughters 68 step...
I had a nice little surprise from another forum I post on this morning when I got up. Bangshift did a small write up on the 68. My daughter was tickled PINK!
https://bangshift.com/general-news/p...s-first-truck/
Today I started on the drivers side repair cutting out and heating up the what was left of the old rocker and backing plate to get it out.
Hope to have all this welding done by weeks end.
Not cutting out near as much on the cab corner on this side as we did on the other side.
Old 11-25-2019, 08:42 PM   #79
2 Stovebolts
Andy...I give you a world of credit....projects like this totally burned me out....but the reward doing it for your daughter is priceless....Bless you.....
2 Stovebolts is offline   Reply With Quote
Old 11-25-2019, 08:59 PM   #80
Andy4639
Old member
Andy4639's Avatar
Yes it does. I've had my moments but I just keep plugging away at it. Hope it's running by Christmas. Keeping my fingers crossed.
Old 11-29-2019, 09:09 PM   #81
Andy4639
Old member
Andy4639's Avatar
Drivers side about done. Spent 8.5 hrs on it today cutting, grinding and welding metal. Oh did I mention grinding on it!
The door shuts good with good gap all around.
More filler welding and then more grinding it should be good.
Old 11-29-2019, 10:53 PM   #82
ashx2
It's coming along nicely. Keep bangin' away, Dec. 31 is just around the corner now!
Greg
ashx2 is offline   Reply With Quote
Old 12-02-2019, 08:28 PM   #83
Andy4639
Old member
Andy4639's Avatar
I really like these new push on door weather strips I got from GMC Pauls. They fit great and are super easy to install. All I did was scrap all the old sealer off and I had to tap the lip in a couple of places to insure they would grip the molding. They are great and I will be ordering another set for the 71C-10. I have a set for the ramp truck already.
I installed both door handles and adjusted both doors. They shut good and tight and the doors align good with the body.
Old 12-05-2019, 08:24 PM   #84
Andy4639
Old member
Andy4639's Avatar
Door regulators and latches showed up. Waiting on the vent window rebuilding kit to get here to start back on the door's. I got the glass back in the frame for the side glass. I took one vent window a part to have it cleaned up and painted so I can get started with rebuilding it.
Old 12-05-2019, 09:44 PM   #85
2 Stovebolts
Keep at it.....Can't wait to see progress in its entirety....
Old 12-07-2019, 10:19 AM   #86
Grumpy old man
Grumpy old man's Avatar
Are you going to paint it while it's completely stripped down ?
Old 12-07-2019, 12:02 PM   #87
Andy4639
Old member
Andy4639's Avatar
Nope! It's a rust bucket kind of truck!Oh excuse me I mean patina truck!
I'm even thinking about stripping it down to bare metal and clearing it maybe.
Old 12-11-2019, 10:08 PM   #88
Andy4639
Old member
Andy4639's Avatar
Drivers side door is done except for the inside panel, arm rest and new window crank. I also put the dash pad in and the wiring is back in the truck. Passenger side will be soon. I have to get the vent window done first though.
Question for ya'll though... The drivers side door shuts good and has no gaps that look out bad. But for the life of me I can not get the dang door to lock!!! What am I missing? The passenger side shuts and looks just fine. Any thoughts on this. I adjusted the sticker for over 2hrs today and it want lock. I can open the door and it locks just find no binding.
Old 12-11-2019, 10:14 PM   #89
Andy4639
Old member
Andy4639's Avatar
I painted the inside heater box stuff and have the heater core in and it's all ready to install. I got the fan motor gasket today to.
Old 12-17-2019, 07:29 PM   #90
Andy4639
Old member
Andy4639's Avatar
Got the passenger side window in and all the rubber seals installed. New door latch. Wired up the wiper switch, dimmer, key switch, starter and HEI. I cut the resistor wire right at the fuse block and added a normal wire to the cap. Got the ground straps hooked up to the frame cab and motor.
Old 12-18-2019, 12:24 PM   #91
68 P.O.S.
Great progress Andy. Keep it up, it's looking good! I wish my progress could be as swift
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-18-2019, 07:30 PM   #92
Andy4639
Old member
Andy4639's Avatar
Thanks,
had another good day in the shop. Swapped the old rod gas pedal out to my old 71 cable pedal. Got the transmission cooler lines all done. Heater box is all done, cables and wired up. Got to install fan motor. Dash is temporarily hooked up to check electrical stuff out tomorrow. New fire wall & radiator plastic tray for wiring installed. Got to strip the wiring harness for the internal alternator and install the head light relays.
Old 12-19-2019, 12:03 AM   #93
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
That's coming along nicely Andy. Bet she's getting excited.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-19-2019, 12:16 PM   #94
Happy_dan
Happy_dan's Avatar
I am always amazed at the things you all do! I stress about changing a window regulator.
Great job Andy, love following this thread.
1968 C-20 CST Vermillion
http://imageevent.com/happy_dan/dantoys/68c20
2019 Silverado
2012 Camaro ZL1
Happy_dan is offline   Reply With Quote
Old 12-19-2019, 12:49 PM   #95
2 Stovebolts
Its amazing how much you get done with a gun to your head, with a deadline....
Old 12-19-2019, 02:48 PM   #96
landarts
landarts
Coming along really nice, cant wait to see the finished product. Good job!
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
69 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 12-23-2019, 08:16 PM   #97
Andy4639
Old member
Andy4639's Avatar
Got the drivers door latch replaced with new one installed Tilt column waiting on the DD/ to 36 spline union to show up to finish installing it. Got the heater box all back in and wiring harness is all hooked up. Lights are hooked up temperarly to try the wiring out.
I was told today I have until Jan 31 2020 to be done. I shouldn't have any problem with that.
Old 12-23-2019, 08:27 PM   #98
2 Stovebolts
Wow..shaping up nice.....
Old 12-24-2019, 08:44 AM   #99
Happy_dan
Happy_dan's Avatar
Great work on this one! So fast!
2019 Silverado
2012 Camaro ZL1
Old 12-24-2019, 09:06 AM   #100
Andy4639
Old member
Andy4639's Avatar
Thanks, I've been getting after it. I still have a ways to go but hopefully by the end of Jan. it will be under it's own power.
