Old 11-13-2018, 02:43 AM   #1
benw88
68 Step-Side, Should I be towing this? Seeking opinions!
Hi all,
I am currently towing my boat with my truck. The boat weighs about 4,000lbs I think. I am wondering what your guyses opinions are. Is this too much for this truck? is it safe? Let me know. Below is how the truck is set up.
1968 C10 Stepside:
Motor:
5.7 350 SBC (less than 3K miles on motor)
AL Heads, Edelbrock intake, Edelbrock Carb, Comp Cam, Headers, MSD Billet dizzy with MSD Ignition box 6AL(?)
Trans:
Rebuild NV4500 conversion (5-spd)
Added cross member under Trans, also still have the original cross member under the bell housing. Had custom 1 piece driveline built.
Rear end:
Stock 12 bolt gm truck rear end, completely gone through, every bearing, seal axel etc. Eaton Posi-Carrier. Springs, shocks and Firestone airbags for the towing load.
Brakes:
Front Disks (all new)
Rear drums (all new)
benw88 is offline   Reply With Quote
Old 11-13-2018, 02:44 AM   #2
benw88
Re: 68 Step-Side, Should I be towing this? Seeking opinions!
Ohh the Boat is a 24ft 1969 Tollycraft in case in anyone is curious.
Old 11-13-2018, 06:37 AM   #3
72 tigger
72 tigger's Avatar
If you’re not out on the freeway or going long distances, l think you’re fine. Just try to give yourself enough room to stop
72 tigger is offline   Reply With Quote
Old 11-13-2018, 06:55 AM   #4
Boog
laying low
Boog's Avatar
You have a working brake controller and good trailer brakes? Nice truck too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-13-2018, 06:59 AM   #5
jjzepplin
jjzepplin's Avatar
Yeah, I would say trailer brakes would help a ton or two. If you get sway you could upgrade to an anti sway type hitch. I would like to see your air bag setup! Nice truck!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-13-2018, 10:07 AM   #6
Mike C
Mike C's Avatar
Can't say that I've ever seen electric brakes on a boat trailer...
But they bring up a good point, a boat that size behind a truck that weighs less than the load needs trailer brakes. A good working surge brake setup changes the conversation as far as traveling at any speed.
I pulled my Malibu ski boat with my Jimmy for a long time. It was probably around 4000# boat/trailer total. It does have surge brakes on the trailer. With your overdrive you don't have the same limits that I did without.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-13-2018, 10:19 AM   #7
Chevyland
Chevyland's Avatar
I would not tow that boat with a 1/2 ton Shortbed
It can be done, but if I was going long distance or highway speeds, my knuckles would get to white, and my shoulders would hurt from the stress.
To me, it needs a 3/4 ton truck.
Just because, a truck ‘Can’ pull something, doesn’t mean it is safe
Chevyland is offline   Reply With Quote
Old 11-13-2018, 10:53 AM   #8
davepl
davepl's Avatar
Trailer needs a hydraulic surge break, then you're OK for towing in town and to the marina and stuff (likely) but I wouldn't get much more adventurous than that with one of our half tons. 3/4 or 1T maybe, but suspension has come a long way in 50 years I think!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-13-2018, 12:36 PM   #9
benw88
Thanks for the replies everyone.
Trailer has working surge brake. I have done a few emergency practice stops and I feel okay about them. Currently I only tow it to the marina and back which is only 4 miles round trip.
I am curious what you guys think the limiting factors are. If it’s suspension and brakes those can be beefed up right ? Or is it the weight over all ?
Old 11-13-2018, 12:37 PM   #10
benw88
Thanks for the reply. What do you mean when you said that I don’t have the same limits as you do with my overdrive ?
Old 11-13-2018, 01:23 PM   #11
Mike C
Mike C's Avatar
I used to pull my boat 200 mile round trip. With speedlimits at 75+, I darn near got run over all the time. My Duramax a better choice for me for what I do now.
But if you only pull 4 miles then it really doesn't matter. My issue was always getting up the ramp in my 70 C2500 2x4. The open diff was a hugely limiting factor.
Brakes, tires, and transmissions seem to be the biggest limiter of load. You have upgraded all of those. I wouldn't be too concerned for what you do. I towed nearly 3000# of decomposed granite behind my 69 short step last month. . Good tires, disc conversion, 11" finned drums in the rear. But lowered 4 1/2"-7". And with the TH350 and the 307 2 barrel combined with the 3.07 rear gear, it is horribly underpowered. But I was only going 45 mph for 3 miles.
Slower speeds and shorter distances do change the conversation. But I always believe that the tow vehicle shouldn't be any (much at least) lighter than the load.
With that said, my Duramax is GVWR at 9500# and tow rated at 16000# so the professionals don't think it's a real issue.
44 Willys MB
52 M38A1
64 Corvette Coupe
