10-22-2018, 09:49 AM | #1 |
valve spring shim question
well i messed up and forgot to shim my springs to the proper installed height before putting in new valve seals...with the seals in, i can not remove the lower spring cup to put shims under the cup...Is it ok for shims to be "in" the cup and just under the valve spring? My shims ID will allow them to go over my seals without removing..Im afraid that ill ruin the new seals if i remove them and i dont want to deal with that..
10-24-2018, 03:10 PM | #2 |
Re: valve spring shim question
I see no one has replied, so I'll suggest calling the maker of the cups. Or maybe Summit.
I have zero direct experience with them, except that I *almost* used them once. I wound up going with a different set of heads and spring setup. I'll share my opinion anyway; at least this will bump your question to the top for a while and give others a chance to weigh in. It's your engine, and you're the boss, so take these with a grain of salt, but if the helpline isn't helpful then here are some factors to consider: Does the cup center the spring from the inside or outside? Often the inner cone of the cup is taller than the outer lip. How tall is the cone or lip of the cup compared to the height of the shims? To me if the height of the shim is less than 10-20% of the height of the lip than I might risk it. Also, the cost of new seals is pretty low compared to the risk of valvetrain failure (I hate valvetrain failures, so that pushes me toward stock setups) and it might give you peace of mind to just take things apart and do it right with new seals. Good luck and let us know how it goes.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
10-24-2018, 03:27 PM | #3 | |
Tks for the reply... My cups center via the outside. I am only needing to shim .030 so there is still plenty of cup left for the spring. I ended up talking to a local machine shop and he said that non hardened shims can only go under the cup...But if you buy hardened shims, you can run them in the cup. I ended up buying hardened .030 shims and am running them in the cup. I think ill be fine since there is only one shim per cup and they are hardened shims... If anyone else has thoughts i love to hear them.. |
10-25-2018, 07:53 PM | #4 |
The hardened shims are what you run under springs with out cups. they will be fine.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-27-2018, 05:00 PM | #5 |
Yes. Those hardened shims inside the cups will be fine.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
Thread Tools | |
Display Modes | |
