Old 04-17-2008, 05:21 PM   #1
truckdude239
truckdude239's Avatar
i need help asap
guys i am now pulling ym hair out i built a 305 for my 71. the 305 is out of a 78 c-10 i've got close to 600 in it and now i relize that it only has one bolt hole for the clucth linage on the side of the motor instead of 2. is there away to get around this???
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-17-2008, 06:04 PM   #2
Ron 586
RIP Mr Ron
Ron 586's Avatar
Re: i need help asap
I had the same problem 20 years ago and this is my way out. (it worked 8 years until I sold the truck) Get a 1/4" X 1" piece of flat stock. Measure how long you need it and drill a hole in it to bolt it to the block. Mount the clutch pivot ball on the other end. (I welded mine) Line it up and tighten it using a good lock washer (the flat ones with the lock around the outside edge. Can't think of what they are called.) Everyone told me it wouldn't work but it did without any problems. That's the cheapest way I could find to get me going.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 04-17-2008, 06:31 PM   #3
truckdude239
ron my already has a bar on the block with the ball mounted to it there are 2 bolts holes on the old motor one above the oil filter the other right at the dipstick tube the new motor does not have the one where the dip stick is.
David fuller
2000 Tahoe 5.3l 378
Old 04-17-2008, 06:32 PM   #4
truckdude239
unless i make it long enought to meet the motor mount
David fuller
2000 Tahoe 5.3l 378
Old 04-17-2008, 09:54 PM   #5
truckdude239
anyone else have any ideas?
David fuller
2000 Tahoe 5.3l 378
Old 04-17-2008, 10:02 PM   #6
truckdude239
the yellow hole is the one i have and the white one is the one i am messing
David fuller
2000 Tahoe 5.3l 378
Old 04-18-2008, 04:51 AM   #7
truckdude239
ttt
David fuller
2000 Tahoe 5.3l 378
Old 05-25-2008, 04:26 AM   #8
bludshaker
bludshaker's Avatar
I am in the exact same boat. Same year truck same year 305. I talked to a machinist friend of mine. He said to drill and tap the block. Nice and slow with good tools.
bludshaker is offline   Reply With Quote
Old 05-25-2008, 04:32 AM   #9
truckdude239
umm i didn't gop that far i just used some lock tite and a good lock washer and so far no problem. only one bolt
David fuller
2000 Tahoe 5.3l 378
Old 05-25-2008, 04:33 AM   #10
Sammy
I have heard of folks tapping the block before so it can be done. Might require taking it to a good machinest. As I wouldn't have the nerve to do it either. You only need a few threads & a short bolt.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-25-2008, 04:35 AM   #11
truckdude239
i wouldn;t have the guts to do it.
David fuller
2000 Tahoe 5.3l 378
