06-21-2017, 11:15 PM | #1 |
Hard to grease...what is going on??
I have an 84 1 ton GMC and after replacing the upper control arm bushings... or dog bones, it seems just the grease fittings toward the firewall are crazy hard to push grease into. I have to squeeze the grease gun like a nut just to watch the handle compress a 1/16 every two seconds.
I did check the fittings by removing them and pushing grease through them but that does not seem to be the problem. I even greased it fresh off the road thinking it may help if a bit of friction (heat so to speak) by movement may allow the grease to flow in a bit faster but no dice. What is the deal? The front ones and lower ones grease up with no effort. Thanks for any help. |
06-22-2017, 12:47 AM | #2 |
Re: Hard to grease...what is going on??
Usually when I have that problem a new zerk fixes the problem..I know you said it works ok when you removed it but try a new one and see what happens...
