02-20-2018, 05:02 AM | #1 |
Radio AM- FM 69-72
Hi all I'm seriously considering buying this radio in the next few days but I do not know what the right speakers are for this type. The original speaker does not work. What advice to clear voice without problems ? https://www.ebay.com/itm/1967-1969-C...53.m1438.l2649
MY Facebook ( saad_alhajri ) on Instagram
02-20-2018, 09:27 AM | #2 |
SWB 4x4 Collector
Re: Radio AM- FM 69-72
That's an aftermarket radio. It is a stereo radio which needs more modern speakers. The factory am/fm radio was a mono speaker.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-21-2018, 01:31 AM | #3 |
What are the appropriate speaker ?
02-21-2018, 05:17 AM | #4 |
Assuming you are only going to use the center dash location for speakers,
then something like this http://www.classicpartsusa.com/produ...8aAlAmEALw_wcB They make kick panels that hold speakers for these trucks if you want more sound that 2 small 3.5" speakers in the center dash. |
02-21-2018, 06:33 AM | #5 |
from the ebay ad description;
speaker ratings listed as well as line level outputs for an external amp if that's your goal.. also selectable for 1,2,3, or 4 speakers so you could run a single modern speaker in stock location.. you mention clear voice as your objective so you could buy an actual analog factory stock am/fm with stock replacement speaker for those results.. depends on how 'original' you're trying to achieve.. as for the modern speakers that will sound decent for music and voice, sky's the limit depending where you're planning to install them.. this might be a good place for you to start to see what sizes are available withing the output specs of the head unit you're looking at.. https://www.crutchfield.com/S-lRuQ8k...kers-Subs.html good luck!
I started out with nothing - and I still have most of it |
02-22-2018, 08:06 AM | #6 |
I have purchased all the necessary thank you all.
