Old 07-15-2018, 09:21 PM   #1
ScottyTightdog
What stall Torque converter?
71 Blazer and I Currently have about 400 hp 350 with granny 4spd and 3.08 gears on 35's. I'm swapping to a TH350 that I am currently rebuilding. I'd like to hear your thoughts on what stall torque converter I should get from people with Blazers and possibly a very similar combination. My plan down the road would be to go to 4.10 gears and maybe 37's as well. Thanks in advance.
ScottyTightdog is offline   Reply With Quote
Old 07-15-2018, 10:02 PM   #2
SatinSeventy2
Re: What stall Torque converter?
Just finished a ‘72 GMC Truck with approximately 400hp and a TH350 with the same 308 gears. I have a 355 full roller with a Comp 282HR cam; went with a Hughes 2500 stall and it works great with my setup. It is very streatable, yet does what it is supposed to do. Hope this helps!
SatinSeventy2 is offline   Reply With Quote
Old 07-15-2018, 10:13 PM   #3
ScottyTightdog
Thx, From my research I was leaning toward a 2200-2500 range.
Old 07-24-2018, 10:05 AM   #4
BIG ORANGE
BIG ORANGE's Avatar
I got a Comp cam and lifters and a 2600 stall I bought and ran maybe 500 miles then took the truck apart to build my 2wd blazer, changed the cam and lifters to a more streetable application and swapped to a 700R4 trans.
the stall fits a 350 turbo trans.
Things happen for a reason!
BIG ORANGE is online now   Reply With Quote
Old 07-24-2018, 10:50 AM   #5
hemi43
hemi43's Avatar
First thing is to change out those gears. 3.08:1 with 35s will be horrible at best. Camshaft selection will usually tell you what converter to use.
FYI, If you try and use a 2500 stall converter, you will overheat your transmission with that tire and gear ratio.
A vehicle is a combination of parts all designed to work together in harmony. You need to design everything as a package, which means you can`t buy a high stall converter now then decide a year from now to install higher ratio gears.
Edit;
I just did a quick calculation of your setup, and at 60 MPH your engine will be spinning 1875 RPM. At this speed, a 2500 stall converter would have in theory over 600 RPM of slippage which is too high. Also, if you have a cam designed to make power in the higher RPM range, your engine will be very inefficient. If you can tell us more about the engine ( cam specs, comp ratio, intake style, carb size, etc ) we may be able to help you a bit more.
hemi43 is offline   Reply With Quote
