02-07-2017, 10:12 AM | #1 |
Belt size a little too long
My engine has been squeaking a little on idle and I've narrowed it down to what I think to be a loose belt. I am using the standard size belt. It's the bottom one, the smaller of the two that goes to the crank and power steering pulley. For some reason, I have it all the way as tight as the power steering tensioner will allow and it is just not snug enough and I think that's why one of the pulleys is squeaking. Is there another belt that is the right specs but just a tad bit shorter that I could use? Anyone else run into this issue?
Thanks!
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
02-07-2017, 12:23 PM | #2 |
Re: Belt size a little too long
Take the belt to the local parts store. They can measure it or get the length from the part number. Get one about 1 in. shorter. A little bit goes a long way.
02-07-2017, 12:29 PM | #3 |
this was the method I was going to do, just wondering if anyone else had a similar thing happen
02-07-2017, 12:48 PM | #4 |
if the belt is real close to fitting an inch longer will be too big. I would find one that is about thickness of the belt longer. I just made several trips to parts store to get one to fit. a little bit makes a big difference.
02-07-2017, 12:49 PM | #5 |
I see your point. In this case though, the belt is too big. I need a slightly shorter belt.
02-07-2017, 01:16 PM | #6 |
one inch is a lot it this belt already fits, belts are usually measured by the manufacturer in mm... what brand belt and what setup (serpentine, v-belt?)
02-07-2017, 01:28 PM | #7 |
It's a Gates 7350 belt.
02-07-2017, 09:11 PM | #8 |
Consider the width of your power steering belt, if it is to narrow it will be too deep in the v grove. Wider belt will have more bite in the pulley v grove! My original p/s belt fills the pulley flush or a little more to the top of the pulley! NO SQUEEK SINCE 1969--36,000mi. hope this helps! HAPPY TRAILS
02-07-2017, 09:56 PM | #9 |
Go down a 1/2". Your belt is a 7350, get a 7345. At lest that's how I understand the belt numbers work...unless they changed to metric. The last three digits are inches and fraction... 450 = 45.0" and 455 = 45.5". That's always worked for me
02-07-2017, 10:32 PM | #10 |
That is correct right to a T
03-06-2017, 04:19 PM | #11 |
Thanks yall.
They didn't have any 7345s in stock, but they did have 7340. It was a little short, but I was able to get it on there with the assistance of a flathead screwdriver. Got it tightened down and no more belt squeal!
03-06-2017, 07:37 PM | #12 |
now keep the new belt package in the glovebox so you will know next time what belt to get.
11-23-2019, 01:27 PM | #13 | |
http://67-72chevytrucks.com/vboard/s...42#post8631742
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 |
11-23-2019, 01:58 PM | #14 |
the belt sizing above is correct, thanks Tim..
since the adjustment travel is only half of the belt's circumference, there should be plenty of sizes to choose from.. but the bigger question I have is why the stock size belt wouldn't fit assuming the factory brackets and pulleys are in place.. have you loosened all pivot bolts and adjustment bolts completely and checked for full range of motion? engine size and year not disclosed and I'm not sure for which engines and when brackets changed, but I would verify that first.. there has to be a reason the correct spec belt that fits a million trucks doesn't fit yours.. good luck!
I started out with nothing - and I still have most of it |
11-23-2019, 02:11 PM | #15 | |
Let's investigate
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 11-23-2019 at 02:33 PM. |
11-25-2019, 07:50 AM | #16 |
I would entertain that the
power steering pump was changed at least once and a smaller pulley was on that pump already and didn’t get changed to the original size |
11-25-2019, 12:08 PM | #17 |
Who Changed This?
Now, there's a thought! After all these years, who knows what could have been done? When I think back on all the things I did, that wouldn't be a surprise.
11-25-2019, 01:03 PM | #18 | |
Belt would sit lower in the groove and not make contact with the groove sides. Belts are supposed to sit level with the edge of the pulley. Check the width of the belt too. |
12-01-2019, 07:15 PM | #19 |
Dear fellows, thanks for your posts and your opinion highly appreciated.
Some investigation done: 1. Remember 1968 327 with PS (Power Steering), AC (Air Condition) 2. Assuming that the original belt routing as as follows (see picture 1): Drive shaft 3 groove to Power Steering 1 groove Drive shaft 3 groove to water pump/fan 2 groove to generator 1 groove Drive shaft 3 groove to water pump/fan 2 groove to Air condition 1 groove 3. Assuming that the original parts are mounted: 379194361 Steering pump pulley (picture 2) 3923898 Drive shaft pulley (picture down below) 3924557 Steering pump support (picture 3)
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 12-01-2019 at 07:50 PM. |
12-01-2019, 07:36 PM | #20 |
The pump was changed in 2018
First picture pump before 2018 installed, Banjo Style Power Steering Pump, second picture now installed, different form.
12-01-2019, 07:43 PM | #21 |
If it comes to the belt 7350 the length is 35.57" this is a little bit longer than the original one 35".
The original with is 3/8" (0.375") , the 7350 has 13/32 (0.41"), but in my opinion the belt has a good setting in the groove. The only explanation I have is that the pump himself with the newer design has not exactly the same geometry and together with the slightly longer belt it comes to the difficulties. Will ask the workshop guys which pump they have installed, I was in this time under time pressure and have not followed the process deeply. Anyway it was great fun to investigate all the part numbers and learn about my truck from all of you.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 12-02-2019 at 03:02 AM. |
12-01-2019, 08:11 PM | #22 | |
My grandkidz showed me how to become high/modern tech with my iPhone and the "Notes" app, I've got a section for each vehicle with pertinent info for belts, hoses, brakes, bearings, filters etc., etc. Even got one for my forklift!.....You are Welcome! |
12-02-2019, 10:20 AM | #23 |
Today I found out that the banjo style and the teardrop style have the same dimensions regarding holes and bolts. Its just a different reservoir style.
https://www.tuffstuffperformance.com...tructions.html No idea why the 7530 belt is to long.
