07-13-2019, 08:56 AM | #1 |
Active Member
Should I be Concerned?
I found these pieces in my oil pump pick up screen. The engine is a 75? 454 and ran great when removed. My plan was to remove reseal and reinstall without a rebuild. I checked the timing gears and oil pump but did not see anything broken. What else should I be looking for or is this possibly from a past event?
07-13-2019, 09:08 AM | #2 |
Re: Should I be Concerned?
Plastic (nylon) or metal?
Check with a magnet. Nylon could be from old timing chain. I had an oil pickup on a 396 that was half clogged with nylon once. Replaced it with no problems. |
07-13-2019, 09:20 AM | #3 |
Active Member
Definitely metal
07-13-2019, 09:48 AM | #4 |
If it ran good just ignore that stuff.
Oil pumps won’t let anything big go thru without exploding! |
07-13-2019, 12:01 PM | #5 |
07-13-2019, 12:57 PM | #6 |
Cluster King
My bet is they are pieces of a broken crank gear. I have done it myself and have watched others do it. Break the gear with a large chisel and hammer, Two good whacks and wha la.
The process is to remove the gear for a chain/gear replacement. Proper way is use a puller Problem is, how they break. I have never lost a piece but could be possible. Seems heavy to get in the screen but floating in oil, who knows. I could be very wrong
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
