Old 09-05-2016, 02:18 PM   #1
CowboyCadillac
Cowboy caddy needs longer front drive shaft...?
Howdy guys and gals,
When we got the caddy, the front driveshaft was out and we'd like to get the 4WD back online for the comin winter season. I believe the shaft was too short to work effectively with the significant lift that is on the vehicle.
How do we determine the correct driveshaft length? Can we have the existing shaft modified once we're able to determine the proper length? Any suggestion or info is much appreciated.
Thanks!
-Heather
Cowboy Cadillac
70 Suburban
Bend Oregon
CowboyCadillac is offline   Reply With Quote
Old 09-05-2016, 03:23 PM   #2
magicoolbus
magicoolbus's Avatar
Re: Cowboy caddy needs longer front drive shaft...?
Any reputable driveshaft repair/fab shop will have a driveline calculator form that they will require to be completed prior to any work and prepare a cost estimate. Here's the one I have used in the past. It is a local one for me, so shipping has never been considered.
http://azdriveshaft.com/
Click on link for "how to measure" and there are many forms for your specific application.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 09-06-2016, 09:44 AM   #3
ranger danger
ranger danger's Avatar
The drive shaft is "Splined" in the middle so it can get longer or shorter as the suspension articulates. The amount of lift you have will determine how long the splines will be. Usually around 7 inches. Anyone who makes driveshafts will be able to calculate this for you no problem.
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 09-06-2016, 10:03 AM   #4
CowboyCadillac
GREAT!! Thank you for the info and the help. Next stop = driveshaft repair shop.
Cowboy Cadillac
70 Suburban
Bend Oregon
Old 09-06-2016, 10:05 AM   #5
ranger danger
Most welding shops do drive shafts. I'd start there. Make sure they balance it as well.
NRA Life Member
