11-11-2012, 07:54 PM | #1 |
dash illumination question
Having a senior moment here and I can't remember if the Heater/Temp/Fan/Defrost controls should be illuminated on my 1972 Blazer.
Pretty sure they do NOT on the non-AC trucks but do on the AC version. Would like confirmation that I do not have burnt bulbs I should be chasing down. Also confirm that AMFM radio only illuminates if the radio is on. Thanks. Tbruz |
11-11-2012, 09:03 PM | #2 |
Re: dash illumination question
There is one bulb on the left hand side of the heater controller behind the white letters. Yours may just be burned out.
11-11-2012, 10:58 PM | #3 |
Thanks, found it and it is burnt out.
Tbruz |
11-12-2012, 08:20 PM | #4 |
The replacemant bulb, # 57, G4.5 BA9s(3 watt) appears overly bright; I do not want to over heat and damage the housing area.
Is there a Bulb chart for the Blazer that shows what bulb should be in there? Does anyone know the specifc bulb number? Correct bulb is #53 Thanks Tbruz Last edited by Tbruz; 11-16-2012 at 04:23 PM. |
