Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-16-2019, 10:54 PM   #1
JoeKan
JoeKan's Avatar
Air compressors
Does Husky make a good air compressor? I'm looking at the 30 gallon they have at Home Depot. $300. I will mostly be using it for painting and DA sander. Thanks.
JoeKan is online now   Reply With Quote
Old 08-16-2019, 11:47 PM   #2
JoeKan
JoeKan's Avatar
Re: Air compressors
Found this one, what do you think?
80 gallon Campbell&Hausfeld electric air compressor $500
Old 08-17-2019, 09:43 AM   #3
nsb29
nsb29's Avatar
Re: Air compressors
A DA takes a lot of air painting not so much. Get one with pistons donít get a diaphragm pump they will drive you crazy with the noise. look at Harbor freight and see what they have 5hp donít worry to much about tank size thatís for storage, they put big tanks on small pumps a lot but then you have to stop and wait for it to catch up
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
Also A/C center duck for 65 Chevelle
3-D scanning and printing of rare and obsolete parts
nsb29 is offline   Reply With Quote
Old 08-20-2019, 01:33 PM   #4
toolboxchev
Re: Air compressors
The most SCFM is what your looking for. Square Cubic Feet per Minute of air. You will need a lot for a DA. Match what the requirements are for the sander, or as close as you can get for your budget. Too little of air makes for waiting for the compressor to catch up all the time. Or it burns up from being overworked.
toolboxchev is offline   Reply With Quote
Old 08-20-2019, 04:18 PM   #5
tinydb84
tinydb84's Avatar
Re: Air compressors
Buy bigger than you think you need. I have a 60 gallon 5hp single stage. It works great but I wish I would have went with a 80 gallon two stage. The scroll compressors are really nice and I might go that route if/when my compressor goes.
David
Instagram: myfabguy
Old 08-21-2019, 08:58 AM   #6
nsb29
nsb29's Avatar
Re: Air compressors
I bought this compressor somebody made it from an old propane tank probably around 40 gallons almost 40 years ago, over the years I have replaced the motor and the pump several times. The pump that’s on there now is rated at five horse I bought it from Granger five or six years ago I believe it was around $600. the following year I replace the motor which is rated at six horse power it also was in the neighborhood of $500 or $600 100% duty cycle I can sandblast all day or run the DA with no problem, it does not shut off but has enough cubic feet to keep up I never have to stop and wait for it to build up. there’s a lot of difference in five horse Compressors, as stated above it’s all about cfm and I would never buy anything by Campbell House field but most 5hp compressors are adequate for Painting and small sandblasting or DA jobs [ATTACH]1930634[/ATTACH
Old 08-21-2019, 03:31 PM   #7
Dead Parrot
Re: Air compressors
Avoid the oil-less compressors. As noted already, they are really noisy.
One way to think about it: Tank size = battery. Tank pressure = voltage. Motor/pump = charger.
I have a 2HP twin cylinder single stage that I got from Northern Tool as a refurb unit for $300. Had one of their coupons that basically canceled out the tax. Looked identical to a $550 unit at Lowes except the NT tank is black instead of Lowes blue.
It won't keep up with a 1/4" angle grinder full time. But the 30 gallon tank will let me run it for a couple of minutes non-stop before the pressure drops off too much. Which is enough for most of things I do.
Budget about $100 for fittings, hose and plumbing to bring air out to a 1/2 pipe setup with a larger regulator. The regulator included on many compressors is often 1/4" and can restrict airflow. Mine had a plug on the side of the tank that allowed for a fitting and hose to connect to a 1/2 pipe network in my shop. If you are starting from scratch, look at the Rapid-air type systems. I already had several long pieces of 1/2 piping and fittings salvaged from another shop setup.
Dead Parrot is offline   Reply With Quote
Old 08-27-2019, 06:50 PM   #8
72c20customcamper
72c20customcamper's Avatar
Re: Air compressors
I bought a 60 gallon Dewalt . Really with the advent of new electric and cordless tools the only big thing I run on mine is a sandblaster and my HVLP spray gun. Sometimes my compressor doesn't run for days.
Mark
72 c20 custom camper Husky edition,66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark
1969 AMX ,02 Springer. 03 anniversary Fatboy.
81 Honda automatic 1600 miles
2012 Road Glide Ultra 2015 Honda Goldwing
1968 c20 stepside 1977 Suburban
72c20customcamper is online now   Reply With Quote
Old 08-29-2019, 10:38 PM   #9
72HuggerK20
Re: Air compressors
SCFM stands for Standard Cubic Feet per Minute in regards to fluid flow rates. In this case, it is describing an air compressor's capacity at a given pressure and temperature. The "Standard" part of that unit is the same as in STP or Standard Temperature and Pressure when talking about the ideal gas laws in chemistry and physics. Standard temperature and pressure is 0 psi (or 14.7 if not counting natural atmospheric pressure), at 68 degrees F and 36% humidity.
So what this means is that the SCFM rating is taking with an open outlet port on the pump with only atmospheric back pressure. On the contrary, a standard air compressor rating of XX.XX CFM @ 90psi is much more applicable because that means it was tested with 90psi back pressure on the pump outlet, which is a much more applicable test when it comes to air compressor capacity.
72HuggerK20 is offline   Reply With Quote
Old 08-29-2019, 11:25 PM   #10
Warrens69GMC
Warrens69GMC's Avatar
Re: Air compressors
Originally Posted by nsb29 View Post
..... and I would never buy anything by Campbell House field but most 5hp compressors are adequate for Painting and small sandblasting or DA jobs [ATTACH]1930634[/ATTACH
Almost all of the compressors less than $1000 are made by Campbell Hausfeld, This includes Porter Cable, Husky, Speedaire by Grainger
1969 307, t350
1950 Chevy Wagon
Old 08-30-2019, 02:48 AM   #11
mikelom
Re: Air compressors
Check out Tractor Supply. They have decent options also.
mikelom is offline   Reply With Quote
Old 08-30-2019, 08:54 AM   #12
nsb29
nsb29's Avatar
Re: Air compressors
That is interesting you never know who made what anymore the compressor pump I bought from Granger was made in USA but itís been too long ago and donít remember Who it was but the pump by it self cost more than most complete units Nothing Iever bought from Campbell housfeld was worth a s?$) so many companies now just put their name on Chinese junk A few years ago I bought a inexpensive belt sander from Home Depot it had black +deckerís name on it the other day I was in Loweís they sell the same sander with craftsmanís name on it I remember when craftsman was a good Reliable product but then I guess that tells you my age ha ha
Old 08-30-2019, 09:11 AM   #13
Warrens69GMC
Re: Air compressors
Bought this compressor after researching my options, made by Campbell Hausfeld
https://www.grainger.com/product/SPEEDAIRE-3-0-HP-1NNF7
1969 307, t350
1950 Chevy Wagon
Copyright ©2000 - 2019, vBulletin Solutions Inc.
