06-20-2019, 09:45 AM | #1 |
Best, longest lasting frame paint
I'm having the frame and rear axle sand blasted so they should be completely rust free, I've read for sure to use an epoxy primer but what about paint? The only other frame I've ever did I just used farm implement paint, I got rid of the truck shortly after so I have no idea how it held up...
06-20-2019, 12:27 PM | #2 |
Post Whore
Re: Best, longest lasting frame paint
i sanblasted, then epoxy,then rustoleum on my frame
06-20-2019, 02:40 PM | #3 |
If you want it to look like factory black use two coats SPI black epoxy.
06-20-2019, 03:49 PM | #4 |
Yep and you’re dun!
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
06-20-2019, 05:10 PM | #5 |
Post Whore
kinda wish I had gone that direction with the spi...maybe next time
06-23-2019, 08:41 AM | #6 |
I'd like to go with a top coat of something with a little gloss, what would y'all recommend? Also when I get it back from sand blasting would it be ok if I shot it with some primer to keep any rust away until I had everything done to where I was ready for the final paint?
06-23-2019, 09:07 AM | #7 |
If you prim it and let it sit you will have to scuff it before paint. That’s a lot of work, use an epoxy primer and then paint within the window of the primer you’re using for a Chemical bond it will save you a lot of work. Spi has more of a gloss than original I recommend it for an epoxy primer if you want it shiny you can top coat it
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent Last edited by nsb29; 06-23-2019 at 09:13 AM. |
06-23-2019, 09:52 AM | #8 |
So if I use spi epoxy how soon should I put a top coat on?
06-23-2019, 12:20 PM | #9 |
Post Whore
The tech sheet says 2-18 hrs....http://www.spiuserforum.com/index.ph...-06-2013.2427/
My epoxy had 12-24 hrs but I did mine at 12
06-23-2019, 01:35 PM | #10 |
The book I have says you have up to seven days to paint . Google SPI epoxy.
06-23-2019, 01:51 PM | #11 |
Post Whore
Is this not talking about paint(base)?...
"the best application of base is within 2-18 hours (no sanding is needed within this time frame)."
06-23-2019, 05:06 PM | #12 |
I think it makes a difference if it was reduced or unreduced, on all my body panels I used slick sand and and they recommended 24/48 hours or longer. I didn’t top coat frame parts. I figured you had a window of 1 to 7 days when unreduced I would call them an clarify it
06-23-2019, 09:36 PM | #13 |
What stores carry spi?
06-23-2019, 09:42 PM | #14 |
Post Whore
i think you order direct from SPI
06-25-2019, 10:54 PM | #15 |
Im getting a lot closer to being ready for paint, there's some areas that I know that sand blaster won't be able to get to like down inside the main suspension crossmember and in behind all the mounts, I'm assuming it should come back pretty rust free but would y'all recommend shooting the entire frame with a rust encapsulator before primer or just the area's I mentioned, or not at all?
06-26-2019, 11:18 AM | #16 |
I would say read or ask about doing this from the primer or epoxy manufacture you intend on using ,they all seem to have there opinins when covering bare metal with there spacific products. If you are using SPI epoxy ,I would give Barry a call at SPI .
06-26-2019, 04:01 PM | #17 |
Sandblasting is quite effective at reaching nooks and crannies, so I would say you would be surprised how clean it will be after, given your blaster does a good job. Regardless of the situation, bare metal needs an epoxy primer, from there you can top coat if desired. SPI epoxy doesn’t have to be topcoated when using in non UV locations like your frame or inner fenders. It’s very tough primer, and lays down with a bit of gloss.
Below is a fender cup patch I just sprayed with SPI black epoxy primer.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
06-26-2019, 04:36 PM | #18 |
SPI recommends Ospho if you’re going to use something
06-27-2019, 12:58 PM | #19 |
My painter uses Tamco chassis paint. It has a gloss and looks really good on the frame. he also uses their underhood paint for the inner fenders and such as it has a satin finish to it.
06-27-2019, 09:14 PM | #20 |
How much do y'all think I will need to do the frame and rear axle? 1 quart? Gallon?
06-27-2019, 11:06 PM | #21 |
If you are going to give it several coats you will need a minimum of 2 quarts.
07-03-2019, 07:08 AM | #22 |
I ordered 1 gallon of spi direct from them...call them they are very helpful
(Trying to figure out how to post a picture) |
07-03-2019, 07:19 AM | #23 |
07-03-2019, 07:49 AM | #24 |
08-01-2019, 03:21 PM | #25 |
Only if you neutralize it first. They would rather you didn't if you can abrade, or sand the rust of with the correct moh's surface finish.
It's is a last ditch attempt to fix something that needs to be addressed another way. |
