Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-07-2019, 10:53 AM   #1
blazer2007
help sanding this,
I need help sanding this section. I welded in a new wheel well section and I did get a valley on this section but I end up with the filler being sanded flat and not getting the gentle curve of the box. Forget that blotch of filler,I tried to put some on yesterday to build it up abit but was way to hot outside yesterday.Can,t really see but is in this area
blazer2007 is offline   Reply With Quote
Old 08-07-2019, 05:54 PM   #2
mongocanfly
Re: help sanding this,
What type sanding block are you using?....how long is it?
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 08-07-2019, 08:56 PM   #3
nsb29
nsb29's Avatar
Id take the taillight out so its out of the way, you have to work an area large enough that as you sand you get a feel of the shape of the whole area not just a little square your low spot probably is a lot larger than you realize. Use a sanding block 18/20 long with 80grt for shaping, and use less hardner so you have more time to work it
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
Also A/C center duck for 65 Chevelle
3-D scanning and printing of rare and obsolete parts
nsb29 is offline   Reply With Quote
Old 08-08-2019, 09:16 AM   #4
blazer2007
I have an assortment of blocks. I tried widening my filler to a larger area and that seems to work better. Have to remember not to fill just the damaged area but go way past the damaged area. Thanks
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
