Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Electrical
Old 09-28-2017, 10:07 PM   #1
Fuelie57
Temp and Battery gauge don't work
Working on a 1972 Cheyenne with factory tach and gauges. Temperature and Battery gauge are not working. Does this sound like the PC ? If so , is there an easy way to verify ? Thanks !
Fuelie57 is offline   Reply With Quote
Old 09-28-2017, 11:58 PM   #2
franken
Re: Temp and Battery gauge don't work
Dig up the wiring diagram on this site and follow it.
People babble nonsense about the battery gauge. It measures the difference between battery voltage and alternator voltage. More + battery, bad, more + alt good. No current is measured.
There are little inline fuses at the fender/gill intersections you might check.
Check the V input at bothe sides w/ the connector unplugged.
Old 09-29-2017, 08:59 AM   #3
Fuelie57
Thanks franken , inline fuses were blown , temperature gauge and wiring are good . When I ground the wire the gauge works . My guess is that someone has installed the wrong sending unit. Checked temperature with a infrared gun and that's all good . Thanks again !
