Old 05-29-2018, 11:56 AM   #1
desertnick69
desertnick69's Avatar
Rear Brakes
I have a 1998 1500 Silverado, The rear brake hang up. If I pull up to a stop light and start going again the rear brakes seem to HANG ON. There is a pop and they seem to release. Any clues????
desertnick69 is offline   Reply With Quote
Old 05-29-2018, 12:48 PM   #2
JJR
JJR's Avatar
Re: Rear Brakes
My first guess would be either a leaky wheel cylinder or axle seal. Have you removed the drum to see how it looks?
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 05-29-2018, 01:19 PM   #3
Mr_Rich
Mr_Rich's Avatar
Re: Rear Brakes
When is the last time the drum brakes were inspected? I've seen instances where the brake shoe actually wears a gouge in the backing plate and could hang up the brake shoe in the "relaxed" position. Maybe there's a broken or weakened return spring. Either way the drum needs to come off for inspection. I just thought of something else; the master cyl. has a check valve. Could be a lot of gunk build-up in the MC. That happens too. A flush couldn't hurt.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 05-29-2018, 01:39 PM   #4
Kudzupatch
Kudzupatch's Avatar
Re: Rear Brakes
Originally Posted by Mr_Rich View Post
When is the last time the drum brakes were inspected? I've seen instances where the brake shoe actually wears a gouge in the backing plate and could hang up the brake shoe .....
That is where I wold start. I had it happen on a car before.
Kudzupatch is offline   Reply With Quote
Old 05-29-2018, 03:32 PM   #5
speedygonzales
speedygonzales's Avatar
How do you know it's the rear
First how do you know it's the rear?
One way to find out is instead of using the brake pedal to stop, use the E brake pedal. See brake lines below.
Second, find out if it's one side versus the other or both. On the rear, it's not likely to be a spring if both sides are hanging. The chances of a spring being broke on both sides is astronomical.
If both rears are hanging, it's likely the rubber brake lines. The lines have a liner that softens over time. As the mc piston moves back it creates a suction that will pull the softened liner in on itself. When this happens, it holds the brake on.
If it's the front hanging it is most likely the hoses collapsing.
BTW if your brake fluid is black, change it right away. New fluid is clear and your fluid in the reservoir should be close to clear.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
