05-03-2019, 01:43 PM | #1 |
95 4wd yukon rear roll pan and hitch
Got hit in back; so I'm taking the opportunity to add a roll pan and behind license hidden receiver. So who has the best parts? Also need drivers side lower 1/4 patch panel, advise, norv.
05-03-2019, 03:31 PM | #2 |
Re: 95 4wd yukon rear roll pan and hitch
I did this to a 95 c1500 years ago. I think I used Stylin Trucks at the time where I could find a steel roll pan to weld in. Summit has a good selection of roll pans (https://www.summitracing.com/search/...ord=roll%20pan) and hitches should be easy to find.
I did find it to be a PITA to hook up trailers though with this setup, especially the bigger trailers with safety chains, so take that into account before you do it.
Mike |
05-04-2019, 12:36 AM | #3 |
Thank you and dewly noted.
