07-30-2017, 01:09 PM | #501 |
Re: Cheap Tricks
Just saw this again. Some damn good stuff in here. Thank You all! I have a couple. I change my own tires from rim to rim and as many as I have I could not afford to pay someone to do it. I had a Coats 40/40 in Cali but for now it is steel bars from Harbor Freight. Any way breaking the beads seem to be the most difficult part. I came up with a solution. I use the weight of the rear of my 70 4x4. I put a farm jack with a somewhat rounded piece of angle iron bolted to it for the bead of the tire between the hitch of the truck and the tire and jack it down. A bumper jack would work too. I can post a pic if someone is interested. Oh and to air them up I put a ratchet strap around the middle of the tread and make sure the valve stem is out. I have one of those air fitting that clamps to the stem and blows full pressure. Then a little shake back and forth til the bead catches and pop! Bubble balancer gets me close to a good balance.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-30-2017, 03:27 PM | #502 | |
Re: Cheap Tricks
What are you doing in Riverview , Wouldn't plant city be a better fit ? or maybe Apollo beach ? |
07-30-2017, 03:29 PM | #503 |
Re: Cheap Tricks
Why? Actually in Brandon now. Just haven't updated things. I got tired of California with all their Rubicons and Hollisters and being able to swim across a river without being chased by gators.
07-30-2017, 08:52 PM | #504 |
Re: Cheap Tricks
Back to sand blasting, I like the results but it is a PITA, I worked on improving the Harbor freight cabinet like some others have. Cut a hole for a 5 gallon bucket in the solid side, added a 12" fan. blows across your work and out the door on the other side, removes the dust etc, instead of trying to use vacuum to collect it. I drape a woven filter over the open door, it drops about 1/2 the sand into a bucket on the ground. Here is the hi tech cardboard organizer, 5 mins to punch some holes and mount your bolts, etc...sand blasted, and primed. Chunks of cardboard do clog up the sand blast nozzle.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
07-31-2017, 12:11 PM | #505 | |
Re: Cheap Tricks
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
07-31-2017, 12:14 PM | #506 |
Re: Cheap Tricks
Thats one I will be using dfwright.
08-03-2017, 01:15 PM | #507 |
Re: Cheap Tricks
If you can't see it, take a picture of it with your smart phone.
The phone also shows details you don't notice otherwise and you can blow the pictures up. It's great for stamped numbers.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
08-03-2017, 01:38 PM | #508 |
Re: Cheap Tricks
When repainting your truck without pulling the glass you can use a glass tool to lift the edge of the rubber gasket and slide some 12-14 gauge wire under it giving you a clean edge to tape to and once the truck is painted pull the paper and then pull the wire out and you won't end up with tape lines on your rubber gaskets that look terrible , leaves a nice clean gasket against the new paint .
08-03-2017, 03:44 PM | #509 |
Re: Cheap Tricks
Don't throw those rechargeable tool battery tools away. Sometimes they have discharged so much that the charger doesn't recognize them. they just need a bit of a jump. I use jumper cables to a 12volt battery on my 18 volt Dewalt batteries. About 10 minutes on the 12 volt jump and bam the charger sees them now and charge away! Just bought 4 dead batteries (lithium ion) off fleabay for $22 delivered. Jumped them and they are fine. Normally about $50-$100 used.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 08-03-2017 at 03:49 PM. |
07-16-2018, 01:00 PM | #510 |
Re: Cheap Tricks
http://67-72chevytrucks.com/vboard/s...d.php?t=457037
this is a stress analysis some engineer did pertaining to notching the rear of the frame. buddy |
07-16-2018, 01:27 PM | #511 |
Re: Cheap Tricks
07-17-2018, 09:33 AM | #512 |
Re: Cheap Tricks
Was this test done in the sixties? My frame is at least 10% weaker than new and I haven't even notched it yet...HAHAHA!
04-18-2019, 07:04 PM | #513 |
Equal opportunity joke ofender
Re: Cheap Tricks
Its actually a funny that I saved but thought this post should be brought back ttt
Need a jump but forgot your cables..... no problem .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
04-18-2019, 07:11 PM | #514 |
Re: Cheap Tricks
It's brilliant! I thought I was gonna see an upside down battery on top of another. (gel cell of course)
04-19-2019, 10:09 AM | #515 |
Who Changed This?
Re: Cheap Tricks
^ Someone's about to become a member of the "hot wrench" club.
04-19-2019, 10:23 AM | #516 | |
Re: Cheap Tricks
And,you could push start a powerglide car at 35 mph! Mike. |
04-19-2019, 08:41 PM | #517 |
Who Changed This?
Re: Cheap Tricks
Yeah, that push start stuff on PGs stopped after '68. When I worked at a shop right out of the Navy in '76, the catering truck driver was complaining that his brother pushed him for a couple of miles, but his truck wouldn't start. I told him that the THM400 never did have a rear pump, so he was out of luck.
04-26-2019, 05:12 PM | #518 |
Re: Cheap Tricks
Use the electric tongue lift to break tire beads. Works like a charm if you have a heavy trailer like my camper.
04-27-2019, 09:31 AM | #519 |
Re: Cheap Tricks
I use my farm jack to break tire beads. I put it under my hitch of the truck. I bolted a piece of angle iron to the bottom of it and bent the two ends to the curve of a rim and just jack it up. I put a piece of plywood on the ground to keep the rims from scratching. Then use some bars from harbor freight to swap out the tires.
04-29-2019, 09:13 AM | #520 |
Old member
Re: Cheap Tricks
I was taught a cheap way to fix a bolt that needed to stay put when assembling it in the brakes on my 64 SS Impala but it will work on any type of bolt I guess.
I was doing the brakes on the Impala last week and had to pull the right rear axle out to replace the bearing. The bearing has a plate with 4 bolts and nuts holding it in place. The bolts are square headed and have the ends like a wheel stud. I had one that was spinning when trying to take it loose. The cheap fix was after I finally got them all out I took a cold chesil and redid the splines on them all. You don't have to do all of them but I turned the each bolt 4 times in the vise and made new ones in 4 places. It worked just fine. Didn't cost a penny. The best part is I didn't have to wait on the parts.
06-20-2019, 09:45 AM | #521 |
Re: Cheap Tricks
06-22-2019, 10:26 PM | #522 |
Re: Cheap Tricks
This is for doing Upholstery work.
Purchase strong magnets. I use rare earth type. Use the magnets to hold upholstery in place when measuring, layouts or when installing. Works really good on holding masking materials when painting or spraying glue. Reusable again an again! Too many types of tape just don't hold worth a darn and tape has become obscenely expensive.
Ironworking's "diamond" in the rough 58 chevy lwb fleetside custom build. 100% Service Connected Disabled Vietnam Era Veteran. |
06-22-2019, 11:10 PM | #523 | |
Re: Cheap Tricks
Is the Ford C6 capable of push-start? Reason I ask, is because I played around with this on a '81 F-150 with a C6. I've got a substantial hill near here, and would get all the speed I could at the top of the hill. Upon starting down, I'd kill the engine for long enough to lose all power steering(thus I knew the engine had stopped turning). I'd turn on the key in the hopes that it would start by the bottom of the hill. It never did, but I typically regained power steering near the bottom. Was that just my mind playing tricks, or is it possible that I was on the verge of roll-starting it? Granted, this was nearly half a mile of 50+ mph rolling downhill.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
06-23-2019, 09:51 AM | #524 |
Who Changed This?
Re: Cheap Tricks
Someone who knows Fords will have to answer that. Sorry, I have no idea about the C6 having a rear pump or not.
06-23-2019, 02:52 PM | #525 |
Re: Cheap Tricks
I've used this wheel cylinder pin for years as my "dedicated fuel line plug". Works great on 5/16 and 3/8 fuel line. Does not leak a drop. The slot slips over our cross members and keeps the line out of the way while changing out fuel pumps. The slot gives you a good grip when your hands are covered with oil or gas.
