Old 09-14-2017, 01:17 PM   #1
RADustin
73-87 3/4-1ton 2wd to SAS steering box
Which steering box is the best to use when SAS'ing an original 2wd truck?
For cross over steering it appears most use the stock 2wd box in its stock location. Just want to confirm this and also to confirm which pitman arm? Stock or dropped? Lift will be mild. Just enough to comfortably clear 35x12.50s.
Is there any other box that is an upgrade to the factory while I'm at it? I have the stocker, but since everything else will be new I was going to get a new box as well.
Thanks.
RADustin is offline   Reply With Quote
Old 09-14-2017, 02:17 PM   #2
b454rat
Re: 73-87 3/4-1ton 2wd to SAS steering box
Uses stock 2wd box with superlift 1104 pitman arm reamed for GM draglink. Is the truck 1/2 ton or a 1 ton? 1/2 and 3/4 ton will need 6" while 1 ton needs 4". Course this depends on offset of wheels and personal opinion.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 09-14-2017, 02:24 PM   #3
RADustin
It is 3/4 ton crewcab shortbed with a duramax/allision. Axle is a super duty 60 from an 05+ f250.
Crossover steering will be custom/aftermarket.
Thanks.
