02-11-2011, 03:36 PM | #1 |
Anyone use a JL TW5?
I am considering using the JL TW5 w/ my MRP1000 Alpine. It pushes 1000W at 2 ohm and 600 RMS at 4. For information on the sub:
http://mobile.jlaudio.com/products_s...hp?page_id=245 Its a 13" sub, shallow mount, 600 RMS max Im pretty keen on this thing but I am afraid it will be too sloppy for rock and metal music. The local guy told me its wicked and that it will have no problems, but I thought I should get some more opinions! Thanks!
Trevor "You already said spite" |
02-13-2011, 07:47 PM | #2 |
>130dB Moderator
Re: Anyone use a JL TW5?
JL builds a very solid product that will perform better than ever expected. The TW5 will handle rock and anything else for that matter. Just give it the power it wants and all is well.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
02-14-2011, 02:53 PM | #3 |
Great thanks Ace! I actually saw your post when they were being released in 2007 and I thought about just PM'ing you for a review!
Thanks again, I expect it will be the route I take.
02-14-2011, 06:37 PM | #4 |
>130dB Moderator
Be aware, they have a wierd Ohm load ont he coil. 1.5/3 I think. Not a problem if you run a JL amp, but can be tricky when running amps from other manufacturers.
Also, while the resonant freq. of the sub isn't all that low, placing it in a smaller box might give you what you're looking for and not allow the sub to extend WAY down low. Keeping the box right at JL's specs should yeild perfect results for what you want (don't forget to factor in driver displacement/equivlenant volume). Match it with a solid pair of 6.5" components and you're well on your way to a great sounding system.
02-17-2011, 10:12 PM | #5 |
C10 CLUB Y QUE!
i just got one. they sound good. but im a bass freak just need one more
02-18-2011, 07:58 PM | #6 | |
Ah I am not a huge bass man, I just want it to sound clean and good. Are you gonna dump it totally or grab a second?
02-18-2011, 08:36 PM | #7 |
C10 CLUB Y QUE!
I'm hoping to pick another one up.
It sound like two tens. If u have it I a center counsol Facing down Posted via Mobile Device |
02-20-2011, 02:10 PM | #8 |
I looked into using one, decided i couldnt afford everything to go with it (amp etc). I was going to buy the JL 5 chl amp to pwr it and 2 6.5" speakers. I loved the low profile sub, it would work great with the limited space most truck have. I went with a low profile pioneer in a custom box with a alpine amp.
turned out pretty good, good solid bass.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
02-20-2011, 10:19 PM | #9 |
Looks wicked, is that a 10"? I was considering dual 10" shallows but the local shop swears by the TW5's and wouldn't try selling me anything else.
02-20-2011, 10:50 PM | #10 |
Correction, it is a 12" and I just checked crutchfield and they still have them.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit Last edited by Red68; 02-20-2011 at 10:55 PM. Reason: incorrect info |
02-20-2011, 11:06 PM | #11 |
Ah yeah, there is so much free space it makes it look smaller, thanks! Anything Pioneer always sounds good.
02-20-2011, 11:22 PM | #12 |
you comin out to spanish banks grobble?
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
02-20-2011, 11:32 PM | #13 |
I hadn't planned on it, I rarely head into the city. When abouts is it? I wouldn't mind getting some inspiration.
