Old 10-10-2018, 11:56 PM   #1
andyh1956
Rear Sliding Glass Gasket?
Hey any Yall know if a rear slider takes the same rubber as a plain rear glass?
I found a good slider up the barn last night looking for something else (That I Still Aint Found)that I would like to use in my M1008.
Thanks!
andyh1956 is offline   Reply With Quote
Old 10-11-2018, 08:38 AM   #2
Re: Rear Sliding Glass Gasket?
Far as I know they do. Took out a stock window years ago and added a slider into the same gasket. If the slider is meant for your truck, then my guess it is the same gasket.
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 10-28-2018, 01:40 AM   #3
BigJackDaddy
BigJackDaddy's Avatar
I was wondering this myself, last week, as I started fitting my Craigslist-find slider into the window gasket I bought a month or
two ago. It all went in like normal, except I could push harder on the aluminum slider frame when installing it into the truck than
I would have on a piece of glass.
ColoradoMelons.com
BigJackDaddy is offline   Reply With Quote
Old 10-28-2018, 10:14 AM   #4
100%Chevy
Yes,they use the factory gasket.
Put in a bunch over the years.
Mike.
100%Chevy is offline   Reply With Quote
Old 10-28-2018, 01:27 PM   #5
sweetk30
sweetk30's Avatar
some sliders use specific gasket . most sliders have the lip on them to use stock glass gasket .
if the outside of the slider were it sits in the gasket has no center mohawk rib then its required to use specific gasket .
if it has the mohawk rib then it should use a stock glass gasket .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Old 10-28-2018, 06:58 PM   #6
jrpontiac
jrpontiac's Avatar
I had a slider and replaced it with a non slider. I used the same gasket.
1977 Chevy C10 SB, Turbo 5.3ls, TH400
jrpontiac is offline   Reply With Quote
Old 10-29-2018, 01:57 PM   #7
andyh1956
Reason for my question is I found a slider up the barn in my Chevy parts stash from yrs ago. I would like to use it on my M1009 pickup cab top install. The Frankintruck I am building for grand son will get a new one.
sweetK30 I will look at the one I have & see which type I have.
Old 10-30-2018, 07:52 PM   #8
79 Silverado/454
Active Member
79 Silverado/454's Avatar
All the sliding windows that I've seen over the years that reuse the non sliding window factory gasket are after market replacement windows. A good indication that you may have a after market replacement window is they stick out away from the back of the cab. The reason for that is the after market replacement sliding windows have a rim around the center on the frame that fits in the factory non slider gasket that is the same thickness as the standard non sliding glass windows.
All the factory sliding windows that I've seen fit flush against the back of the cab and use a wider black rubber gasket. They were this way from 1973-1983 and the frames were gray aluminum color during these model years.
1984 the factory sliders switched to black frames and used a black rubber seal with a chrome strip in the center that matched the chrome strip like the one that surrounded the windshield gasket on the upper trim levels. Lower trim levels just got a black strip in the center of the gasket in 1984 -1987 IIRC.
1979 C-10 Silverado SWB 454/400 Turbo
2015 GMC Sierra SLT Z71 (Cayenne Metallic)
2018 GMC Denali HD Duramax (Red Quartz)
79 Silverado/454 is offline   Reply With Quote
Old 11-01-2018, 03:55 PM   #9
andyh1956
OK I looked at the slider that's in the '84 cab (That I busted two windows outta) & it is a factory black frame slider.
And the one in the barn is a slider w/ some plastic inserts in each end to give it a slight curve to fit the cab & the flanges look to be about 3/16" wide so a factory solid glass gasket should work.
Thanks for the help!
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
