Old 12-21-2016, 05:45 PM   #1
Toolman_69
Drop Spring Question
Hey guys I have a 69 c10 LWB. I'm currently doing a drop on the suspension and I'm considering my options. I am doing a 3/5 drop with a 1 inch block in the rear. I was wondering since there are from what I can tell only 1 vendor (cpp) that offers a 4 inch drop spring in a heavy duty configuration. Is the ride really rough(Bouncy) with the heavy duty spring in that much of a drop. Should I just go with a normal drop spring. I do want to occasionally use the truck for towing (Jet ski's, nothing really heavy), and the occasional load from the hardware store for home improvement supplies. Those who have done the 4 inch HD spring in the rear can you chime in on how it rides? Thanks
Toolman_69 is offline   Reply With Quote
Old 12-21-2016, 06:17 PM   #2
68c10airstream
68c10airstream's Avatar
Re: Drop Spring Question
I did 2 1/2" drop spindle in front with a 4" ece spring with a 1" block. Shaved the rear bumpstop some, no frame notch. Definitely recommend a porterbuilt pan hard rod kit, shock relocators and i use monroe sensa-trac shocks. Pull the old airstream, loaded 1,000 lbs of pavers and occasionally bottom out, but until i did all of the mods it was a little bouncy, but now love the ride.
68c10airstream is offline   Reply With Quote
Old 12-21-2016, 07:07 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I have not been impressed with the CPP springs. I have the HD 4" dropped one on my panel (which is what they are for) and it dropped more than 4".
I would recommend ECE if you still want to use your truck like a truck.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-08-2017, 01:16 AM   #4
earl1951
earl1951's Avatar
ECE springs for sure! 1965 c10 longbed 4" drop
earl1951 is offline   Reply With Quote
Old 01-12-2017, 08:46 AM   #5
zach_carver
zach_carver's Avatar
Are the ECE springs true to advertise drop? I have POL 5" drop springs but my trucks still higher in the rear than the front by quite a bit..
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
